SOURCE: I would like to know if it is possible to turn off
Press and hold the menu button until the word menu appears on the screen then press the number one on the key pad. Use the up or down arrow to turn ringer on or off. Press save and your all done.
SOURCE: How to put in speed dial #s in 2.4 Hz Bell cordless phone
With the phone offline press MEMO. The IN USE light will flash. Enter the telephone number you want to store and press MEMO again. Then press the number key under which you want to store the telephone number. To use speed dial, press TALK, MEMO, and the number button where the telephone number is stored.
SOURCE: Please give me instructions on how to change the
To Program the 3 Emergency Numbers:
1. Lift the handset and listen for a dial tone.
2. Press and release STORE BUTTON.
3. Enter the number to be stored. (The telephone number will not dial out.)
4. Press and release the STORE BUTTON.
5. Press the corresponding emergency buttons for each of the emergency numbers you wish to store:
6. Replace the handset to the base.
To program 10 frequently called phone numbers:
1. Pick up the handset and listen for a dial tone.
2. Press and release the STORE button.
3. Enter the phone number (up to 16 digits) you want to store into memory (The telephone number will not dial out).
4. Press and release the STORE button.
5. Press a one-digit number ( 0 - 9) on the keypad to store the phone number into the desired memory location.
6. Hang up the phone by returning the handset to the handset cradle on the base.
7. Pull the memory index card tab out from under the unit and write the name/company on the memory index card relating to the phone number just stored into memory.
8. To store more phone numbers or modify existing numbers in memory, repeat steps 1-7.
For additional details, you can download and print the complete instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
