No sound at the main speakers for a JVC model CA-FSP7. The IC is OK . I need a diagram.....please .Tks.
    Scholar:
  • 152 Answers
If you're willing to shell out some money, the manual could be found here. For free, you may try and select the closest model here.
Posted on Sep 17, 2008
  • 2,071 Answers
Try to hooked your main speaker to another reciever to see if it works,if it working then the problem is in the amplifier,try to look for loose ,crack or cold solder joint in the amplifier section until to the output this is the common cause of the problem. Reworks or resolder all solder joint on that section.If it happens the main speaker not working to another receiver then the problem is the speaker,your amplifier is good.
Click below to download manual;
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
http://www.freelists.org/archives/techassist/
http://www.eserviceinfo.com
Regards,
VOTIT
Hopes it may help;
    Genius:
  • 1,269 Answers
Make sure the audio jack from speaker going to the receiver are good cables and tightly connected.
  • Michael Galve
    Michael Galve Sep 17, 2008
    Please download the User's Manual HERE
    Page 7 for connecting the speakers and audio devices.
Any help out there with JVC MX J900 number of fuses in system? Do the speakers have fuses? Can't figure out why no sound.
The most likely cause is the main amp unit. Most of these units use an all in one IC amp that does all the work. If it goes then you get no sound.
The fuses inside the main unit if they have gone would remove all power from the system. Generally they would only go if the main power amp or part of the power supply had shorted. In any case it would generally lead back to the IC power amp. I will post a picture below of what it might look like. There's generally a number on it, you can look that up on line before removing it to find the price of it. The Speakers have no fuses in them.
Oct 14, 2016 | JVC Audio Players & Recorders
My powered sub woofer system doesn't work.power indicator works and fan doesnt no sound
You will need to contact JVC online, customer support and the technical department to see if they can provide at least download on the circuit diagram. The powered sub from your description has a short, probably the main ic that is heatsinked.
Nov 26, 2011 | JVC Audio Players & Recorders
Sound on tv went out. model jvc hd-56g886. Checked mute buttons etc
Hello
You just hold your ears very near to the speaker side, and swich on the tv. If you hear a "thumb"; sound, the output circutary of your tv has some trouble; provided picture is Ok. If there is no "thumb sound", the speaker of your tv must be suspected.
Normally output Ic may get damaged. This will happen to most of the telivisions.
Oct 15, 2010 | JVC Televison & Video
I need the IC # of JVC model KS-RT707
YOU DID NOT SPECIFY EXACTLY WHICH IC YOU ARE LOOKING FOR, BUT MORE THAN LIKELY YOU ARE REFERRING TO THE SPEAKER OUTPUT IC. THIS PART NUMBER WOULD BE AN HA13152. IF YOU ARE REFERRING TO ANOTHER IC, PLEASE BE SPECIFIC, INCLUDING THE LOCATION NUMBER......V
Jan 06, 2010 | JVC Car Audio & Video
Problems with sound/no audio
the internal amplifier IC needs to be replaced to fix this problem
the ic is cheap but not the labor
Dec 30, 2008 | Televison & Video
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Sound from one speaker but not the other
may be power ic one channel failed
Mar 29, 2007 | JVC TH-M505 System
 Grubhead
Grubhead
