Question about Toshiba Televison & Video
Toshiba 20af21 set clicks but does not start. keeps on doing same thing until unplugged
I had this problem so I got rid of the tv, however, I mentioned this problem to a friend and he said he had the same problem, it was just a switch inside the tv that needed to be reset, I know this is a bit vague but thats all I know!! But maybe a tv engineer will be able to remedy this without too much cost!
Posted on Sep 16, 2008
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
How do i reset my toshiba satellite L305-S5955 to factory default & erase all data from it?
Close out any software currently running on your Toshiba Satellite L305 laptop.
Navigate to the laptop's "Start" menu and choose "Shut Down."
Hold down the laptop's "0" key and press the power button.
Keep the key held down during the boot up process until the "Toshiba Recovery Wizard" window loads on the screen.
Click the check box labeled "Recovery of Factory Default Software." Choose the "Next" option.
Choose the "Recover to out-of-box state" radio button. Select the "Next" button and click "Next" again.
Wait for the "Press any key" prompt to appear and tap a key to restart the laptop.
Use the prompts that appear on the screen to choose your region, time zone and keyboard settings.
Type your new Windows user name and password in the text boxes when prompted. Click "Finish" to load the new operating system.
hope this helps
Sep 06, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
Computer ramdomly turns off
Instead of unplugging everything, only unplug 1/2 of the things. If it still won't start, unplug 1/2 of the remaining things (noting which ones they are). If it restarts then, it was one of the last set of things you removed that is the problem, so keep eliminating possibilities in this fashion this until you can determine which component it was. If it turns out to be the power cord, it could be a problem with the power supply.
Mar 02, 2012 | HP Computers & Internet
I have a Toshiba Satellite Pro L300 With Windows Vista on it. Keep getting BOOTMGR during startup. I'm not in the possession of a vista dvd. Seeing this laptop came with the OS...
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
May 30, 2011 | Toshiba Satellite Pro L300 Notebook
System restore factory settings no cd
Toshiba has built in system recovery partition in your hard drive
Make sure to back up important files in your Laptop to usb or portable hard disk before doing this.
Warning: In using System Recovery you files will be deleted, your laptop will be back to its factory settings
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Feb 01, 2011 | Toshiba Satellite A45-S120 Notebook
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
I want to access bluetooth on my laptop
Click Start - All Programs - TOSHIBA - Bluetooth - Bluetooth Settings.
You may also want to look at the task bar and see if the Bluetooth Icon is there.
Most of the time with the New Toshiba laptops the icon will not appear untils you do the first top step. Once you click on Bluetooth settings your laptop will actually install the Bluetooth Module and make it available for you to pair Bluetooth devices.
Oct 09, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Toshiba 46H84 turning off by itself AND all BLUE screen with Black Dot in Center
Try to replug everything in the TV. Before you turn it on. make sure all plugs in the TV to the wall is plug in tight. When you turn your TV on hold the power button down to see if it resets
Feb 28, 2017 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
