Question about Freezers
Frost free fridge hotpoint
When i switched the fridge on it was making a buzzing noise every few minutes kept it on for 24hrs but still did not freeze it was too warm have been changing the temp of it but still nothing . It was bought 2nd hand but was definately working as it came from family
  • 750 Answers
Hot mamamia,
Huuum her to give you good advice.
You said,
When i switched the fridge on it was making a buzzing noise every few minutes kept it on for 24hrs but still did not freeze it was too warm have been changing the temp of it but still nothing . It was bought 2nd hand but was definitely working as it came from family.
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
You will be fine
Bless You huuum
Please give me the best rating at fixya .com before you sign off.
Thank You
Posted on Sep 17, 2008
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
Frosting up badly despite having just been defrosted
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for cold control and air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout.....
Aug 08, 2010 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
My whirlpool freezer was left open by my child and now is emitting a buzzing noise. What is this noise and what do I need to do to fix it?
You may have frost bulidup on evaperator from door being open and fan blade rubbing on ice. turn off to melt the ice 8 - 24hrs then turn back on
May 17, 2010 | Freezers
If you can pull the unit out from the wall, find the motor compartment. There, you'll find a black can with the motor and compressor inside it. This usually creates vibration when running. Check the compressor's mounts, to see if they need tightening or have rubber grommets that have rotted away. The sound could also be coming from a fan somewhere in the machine. There might be a fan in the motor compartment. Find the vents inside the unit that blow cold air. Check the guards to see if a foreign object could have made its way into the vents and jammed a fan. Make sure you unplug the fridge before you stick any hands or tools someplace they wouldn't normally go. You may want to let the unit run while peeking in with a flashlight to locate the source of the vibration, but beware of moving parts and a shock hazard.
Apr 03, 2010 | Freezers
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
My maytag Wide by Side refrigerator started making this buzzing noise coming from the freezer section every few minutes and now it no longer cools.
It is possible that the door was not closed tighly, so the humidity built up in the duct line and the low temperature from the freezer make it turned into ice causing the clogging. The Buzzing noise turns on due to the sensorsomewhre along the disigne path. Unplug the fridge for a day and a half so the the ice in the duct line could melt down then when you turn on the sensor won't turn on the buzzing any more. Good luck.
Jul 04, 2009 | Maytag Freezers
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Fridge Freezer very noisy!
cycling every 30 mins is normal. bear in mind that frost free are more noisy as there are fans running as well.
you appear to have temp in freezer too high - should be -18degC
Oct 11, 2008 | Freezers
Freezers Logo
117 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
