Question about GE 27GT722 27" TV
Channels not working
When I turn the TV on I am not able to change to other stations. I have tried doing it with remote and also the buttons on the T.V. It just stays on one channel. I can turn the volume up and down and thats it. When I go to settings I can only set language, nothing else. thanks Ron
    Problem Solver:
  • 4 Answers
It was in the guide plus set up that I needed to redo. When I was originally using it I had it setup to be connected to cable box, but when we moved it into the other room when we got the new tv we recieved, there wasnt a cable box in there. I didnt know that I just need to reset the menus to delete it being connected to cable box and it worked. I hope this will help someone else if this problem occurs with their TV. Ron
Posted on Sep 17, 2008
Why can i only get radio stations from our humax freesat and not tv channels
There is a button on the remote labelled 'TV/Radio' which was probably knocked when the remote was dropped.
Sep 15, 2014 | Humax Televison & Video
Memorex mt2024 "A"
Hi.
Go to this link: remote codes
Fixya me on this...
Feb 10, 2008 | Memorex MT2206 TV
Why is my remote control not working despite changing the batteries.
Not sure if this will help but, I recently put an antenna on the roof of my house. I don't watch TV much but wanted to enjoy some TV, but my remote locked up and the side buttons on the TV wouldn't work either. I tried changing the battery, but no luck. There's a broadcast station 64.2 that is locking up TV's & remotes. Here's the fix that a TV repair co. gave me which did break the lock of the station 64.2.
1) unplug antenna (not roof but connection from TV to wall)
2) unplug and plug back in TV
3) find a way via remote or side buttons to scan channels
4) Go to Menu
5) EZ Setup
6) Channel Set Up-Scan Channels
7) Channel Memory
8) Digital Set Up
9) Turn Skip On for 64.2 (Delete this Channel)
10) Turn off TB
11) Hook Antenna back
You may have to play with the order to acheive the end result or figure out a way to delete 64.2, but during the process you will at least unlock from being stuck on 64.2.
Good Luck if this was the same issue!
Jul 14, 2014 | Audio Players & Recorders
Dish network changed to snow when I tried to change station to channel 13. I pressed "power" for 5 seconds with no change.
Hi, Mary with Dish Network Customer Service here. It sounds like when you try to change channels with your remote, it is changing the channels on your TV and not your Satellite Receiver. In the top left corner of the Dish Network remote is an SAT button. When you try to change channels on the Satellite receiver this button should be lighting up. If the TV button lights up, it means the remote is working the TV. Press and release the "SAT" button after you have the picture back on the TV and it should work normally. I hope this resolves your remote issue!
Jan 12, 2011 | Toshiba Televison & Video
It is locked to one station and cant be change, only to turn on and off
Are you trying to change channels with the remote? Did you try the buttons on the tv?
If neither work, go into setup and rescan for channels. Maybe the tv (or a prankster) - deleted all but channel.
Are you using a cable box? That would create other possibilities.
Dec 20, 2010 | Televison & Video
Cannot get channels with remote stuck on AV2/3/4/5/6
The TV button on the remote is to select TV mode for the controller. STB, VCR & DVD do the same for their respective devices.
The A/V should select the external inputs by itself. If not try each of the Panasonic codes in turn:
0011, 0021, 0027,0029,0039,0072, 0102
Enter the codes as follows:
Press and hold TV for 3 seconds until the TV key flashes and then stays on.
Enter one of the codes (above)
TV key should flash twice. (if not go back to the beginning)
Try pressing the buttons on the controller. If all the functions do not work, try the next code.
Aug 03, 2009 | Rio Go Video DDV9475 Dual Deck VCR
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV changes channels itself
Have you checked to see if any of the front panel buttons are depressed and stuck??? this is a big problem these days?? I have also found the infared remote sensor to be bad on some sets that do crazy things all by them selfs.. A funny storry once i had was a customer called me after her mother called some goast finders as her maggy projection set would go on all by itself andf the channels would change and the volume would go up and down all by its self. funny thing I had a set just like thast in the shop at the time with the same problem and I scoped out the output pulse from the infared reciver on the set and that was putting out noise on the data line and caused the set to eratacly do all sorts of weird stuff. get the point?? its a stck button or the remote sensor is bad.
Apr 01, 2006 | Bush WS6671 28" TV
Open Questions:
GE 27GT722 27" TV Logo
83 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
