HTC Incredible S Logo
Posted on Sep 18, 2011
How do I set up voicemail? How do I delete
How do I set up voicemail? How do I delete duplicates of phone numbers downloaded by my optus provider? Is there anywhere I can download a free manual HELP!!! I've been into my local optus shop twice but they don't seem to be able to help
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Sep 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
Helped
3501
Points
67
Go htc, apps down load, oh and just call your phone company , are headquarter
1helpful
Mailbox is full, how do I empty it please?
The "10B1" message on your Panasonic KX-TGD390C phone may indicate that your voicemail box is still full, even if you've deleted all the messages. This could be due to some saved or undeleted messages in a different folder or some other issue with your voicemail settings. To clear your mailbox and resolve this issue, you can try the following steps:
  1. Access your voicemail box: Dial your voicemail access number. It's typically a number provided by your phone service provider, such as "123" or "555."
  2. Follow the voice prompts: Once you're in your voicemail system, listen to the voice prompts carefully. There should be an option to manage your messages or change your mailbox settings.
  3. Delete all messages: Even if you've already deleted messages from your phone, there may be some messages still stored in your voicemail box. Use the voicemail system's options to delete all messages.
  4. Check saved messages: Some voicemail systems have a separate folder for saved messages. Make sure to check this folder and delete any saved messages if they exist.
  5. Change mailbox settings: If you cannot find any messages in your voicemail box and it's still showing as full, you may need to access your mailbox settings and reset or reconfigure them. Look for options related to mailbox size, message retention, or other similar settings. You might need to contact your service provider for assistance if you can't find these settings.
  6. Reboot your phone: After you've taken the above steps, it's a good idea to power cycle or reboot your Panasonic phone. This can sometimes help refresh its connection to the voicemail system.
  7. Contact your service provider: If you're still experiencing issues after trying these steps, it's a good idea to contact your phone service provider's customer support for assistance. They can help you troubleshoot and resolve any voicemail-related problems.
Remember that the specific steps and options may vary depending on your phone service provider and the voicemail system they use. It's essential to follow the prompts and options provided by your voicemail system when you access it through your voicemail access number.
3answers
How do I remove the voicemail number
  1. Open the dial pad on the device.
  2. Dial Voicemail. Tapping the number 1 and then hitting the green phone icon at the bottom should call Voicemail.
  3. Enter a password (if there is one). Enter the password for the voicemail by tapping the number keys and then the # sign.
  4. Skip through messages. There may be multiple voicemail messages on the account. Press 9 when listening to each message to save it and move to the next one.
  5. Delete a voicemail. Press 7 on any voicemail to delete them.
If you want any information contact with hp printer support number 1 800 712 0802 HP Printer Support Phone Number HP Technical Support
Sep 29, 2018 • Cell Phones
My vetch phone shows "new voicemail". how do I delete this
To clear the "New Voicemail" display from the handset
is a slightly different procedure for each model of cordless
phone.
Try the following (tested on my own cs6229 phone):
press [menu]
scroll to "Clr voicemail"
press [select]
display reads "Turn Off Indicator?"
press [select]
phone will (chirp) press [off ]
Or, this one (tested on my own cs6114 phone):
press [menu]
scroll to "Settings"
press [select]
press [select]
display reads "Reset VM Icon?"
press [select]
phone will (chirp) press [off ] [off ]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
How do I get messages off my voicemail
cell phone voice mail is done by the network provider . They will have an access phone number like for example telstra in austrailia uses 101 optus in australia uses 321 once you are in the voice mail it tells you the options press (whatever number) for delete message.
contact or look up on the phone network providers web site what this voice mail phone number is.
How do I check my voicemail
contact phone provider or look on their web saite as each provider has a different access number. Optus is 321 while Telstra is 101 as an example in Australia.
then you call the number and follow the voice prompts
2answers
I can't get rid of my voicemail icon on my Motorola Cliq. I don't have a voicemail.
Do backup your data and do a factory reset going to settings . That should fix it .
What button to dial voicemail.
There is no "button" to dial the voicemail. (you didn't read manual).
You access your voicemail by dialing YOUR OWN CELL NUMBER.
(find it here): Menu / Settings / Phone info / Build info / YOUR #.
(copy it down)
If your cell # is: 101-555-1234, DIAL: 1015551234 / hit green phone.
Just follow all the voice prompts to set up your greeting message,
access & delete voicemail messages, etc..
ADD YOUR OWN NUMBER TO YOUR PHONE -- AS A CONTACT.
Place it in double parenthesis, just like this: "VOICEMAIL"
When you open phone and hit the contacts button, it will ALWAYS
be the very FIRST contact in your list of contacts. DARN HANDY!!
15helpful
4answers
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Deleted voicemail access number
also can reset factory settings on some but will lose numbers,messeges,etc.
May 27, 2009 • Cell Phones
Nokia 3110 classic
go to setting then ringtone setting and choose ringtone for voicemail
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
