Question about Mitsubishi SL4SU ColorView Multimedia Projector
Sl4u Projector I work for a school district that has many of these projectors. They are hooked up to the tv and to the computer. I have one that I get no picture. No light, no nothing. I changed the bulb and that didn't do anything. I can hear the fans running but its not turning on. The power light stays green and the status light blinks red. I tried unplugging it and plugging it back in and letting it sit. Nothing is working, any thoughts?
  • sugatasinha Oct 22, 2008
    Start button is not working. It's only shows red.
  • sinquay Oct 25, 2008
    I try to turn on my projector and the lights go from green to flashing one turns red then soon after it's shuts off without showing picture or sound.
It could be that one of the fans has broken you will be able to hear them because there are 5 in there. if you are under warantee send it back if you are technically minded take it apart and watch which fan doesnt start then order from mits or from a local supplier,.
Posted on Jan 02, 2009
Yellow tint on projection mitsubishi sl4u
The polarized glass for the Green LCD panel has gone bad, and require to be replaced.
Oct 05, 2015 | Mitsubishi Sl4u Colorview 3 Lcd Projector...
Have a mitsubishi XL6600u projector .....screen is yellow and have replaced bulb still yellow
Could be one of two problems. How old is the machine? If one of your LCD filters inside the machine has burned up it will show yellow. Common on SL4U. It starts with a yellow circle. If not that then most likely a bad VGA cable. If you have it hooked up that way.
Dec 06, 2012 | Mitsubishi XL6600U New
We have an Epson Powelite projector mounted in a classroom and just recently it is projecting everything with a purple tint to it. Before that the colors were not as vivid as when we first installed it. ...
An image is produced in these projectors by passing color through three different LCD panels. One is a Red, one a blue, and the last one a purple. It sounds like the green panel is damaged. The only way to tell is to take it to an Epson authorized service center.
Mar 08, 2011 | Epson - PowerLite S1+ Multimedia Projector
Have a number of same model projectors lc-sd15 stop working .
Are you a UK school district? the thermal trip has been a problem on sevral makes of projectors including Sanyo, your problem now may be lamps what hrs do you have on the lamps?
Marc Engineer
Apr 06, 2009 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Shows image but is completly yellow
I had one with the same issue. After checking and rechecking the projector, I found that there was a lose conection between the CPU and the RGB output connection. It's really touchy.
Jan 30, 2009 | NEC VT670 Multimedia Projector
HP vp6320 projector ten seconds it shuts off
I had the same problem, the first couple of replacement bulbs i ordered worked fine but the last 3 i got, 2 of them have been faulty, i just sent them back and they replaced them. If its too late to send the bulb back you can go to the settings on projector, select lampsaver setting, its probably set at off, turn it on. Your bulb will be a little dimmer in this setting but shoud let the projector run ok.
Dec 01, 2008 | HP vp6320 Multimedia Projector
Acer laptop stopped displaying to projector
Here is the deal. Right-click on desktop. Choose settings. Right-click on screen #2. Click on apply for new settings. The one additional problem you may encounter is the fact that the projector will display an area to the right of your laptop screen. In other words, move your mouse past the right edge on laptop screen. Look at projector image. See your mouse?
Aug 04, 2008 | Computers & Internet
Problem with mitsubishi sl4u projector
make your pc or laptop start first and then the projector.
Mar 26, 2007 | Mitsubishi SL4SU ColorView Multimedia...
Mitsubishi SL4SU ColorView Multimedia Projector Logo
207 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
