I have a Toshiba SD-24VBSB. This is a DVD Player & Video Cassette Recorder. If I connect my cable box to the AV2 Scart and my TV to the AV1 Scart as recommended in the manual, then I lose Audio if I switch the Toshiba box to standby. Sometimes it lasts for a few seconds before it dies. I think this is a design fault. I called a Toshiba helpline and they suggested I should instead connect one of my cable scarts direct to my tv and the other to my Toshiba, and the output of the toshiba to the second tv scart. Although this works as a workaround it makes it more complicated for me to add a satellite box into the system as I was planning. Has anyone heard of this odd behaviour before or know a solution
2 Suggested Answers
SOURCE: Need to connect the following: Foxtel
how can i recover my dvdrecorder's HDD?
Posted on Mar 09, 2008
Tv dvd and sky box
isn't there any manual/ book?
To connect TV to Sky Box VCR, connect the SCART lead from the AV1 socket on the TV to the TV SCART socket on the Sky Box. Connect another SCART lead from the AV2 socket on the TV to the AV1 socket on the DVD player and an RF cable from VCR to the aerial in socket on the TV.
Apr 27, 2013 | Televison & Video
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
Where to put scart leads into dvd and video player and panosonic tv
Look at the rear of the TV/VCR/DVD & you will see long black sockets where the Scart cable is connected onto, these are normally indicated as AV1/2 etc. You can then take Scart from DVD to TV on AV1. Then on AV2 take the second scart from VCR to TV or you can take the second scart from the DVD to the VCR & from the VCR to AV2 on the TV.
Nov 29, 2009 | Panasonic CT-32SL14 32" TV
How do i connect dvd recorder to tv only receiving sky channels through skybox
If you have two scart sockets on your tv,then connect a scart from av1 on the dvd into the tv,then connect a scart from the sky box into av2 on the dvd,your recording channel on the dvd will be av2.
If you only have on socket on the tv,then connect a scart from av1 on the dvd into the sky box,your recording channel will be av1,connected like this you may have to turn off the sky to watch dvd`s.
Oct 30, 2009 | Televison & Video
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Dvd recorder does not have tv tuner
sure you can record from your TV. You need to connect the AV1 of the tv to the AV1 of the DVD recorder. Then, when the TV is running, you can simultaneously record on your DVD recorder.
Use a SCART cable for the connection.
Jan 05, 2009 | Samsung DVD-V4600 DVD Player/VCR
Cable hook-ups for TV, Satellite Box, DVD, VCR
Use SCART lead from Sat. box to VCR input( so you can record progs.) then another SCART lead from VCR output to TV set AV1 input. Connect DVD (player only I presume) direct to AV2 input of TV set using another SCART lead.
Hope all this works O.K.
Note:- If DVD is also a recorder then you don't need VCR as a recording device and leads will need to be altered accordingly, of course!!
Nov 22, 2008 | Kenwood KR-V7080 Receiver
Connecting a freeview box
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
Aug 08, 2008 | Televison & Video
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
