Question about Kirby G4 Bagged Upright Vacuum
Kirby G4D vacuum
When I plug the vacuum in it does on turn on when I hit the on/off switch. Can you tell me what the problem is? How can I fix it? Hello, I have a G4 Kirby, which I dismantled for cleaning,no problem with the dismantling or reassembly, but now it will not run, it worked before I started work on it, is there anyway I can test the switch while it is out of the machine.
I can't think of anything that I have done to cause the problem, I am motor engineer by trade so have some knowledge of the workings of the Kirby.
I have power to the Kirby two pin plug, the peg on the brush head is engauged with the front switch, and the side emptor switch is also pushed forward, and I have operated the main switch from the inside with the top cover removed, hope you can help,
Regards, Bill
    Genius:
  • 1,550 Answers
You have looked into various facts since you are motor engineer
So there can be two problems
  • It Could be the a/c cord, a problem with the noozle not pushing the safety switch, the bag emptor (bottom of outer bag) isn't on the of the way and not engaging the other safety switch
  • Common fault is the mains lead broken internally, unplug from the side of the machine after removing the little cover where the wire goes in. You can use a kettle lead to test the hoover.
If this does not cure it most likely the motor brushes are worn.
Thanks for using Fixya
SAM ANDERSON
Posted on Sep 16, 2008
  • 958 Answers
Hi, i can help you if you know how to use a VOM.
we will test for continuity.
tnx 4 using fixya,
drcool
  • francis rivero Sep 16, 2008
    a continuity tester would help you trace your problem. just follow the wire from the power cord to the motor leads.
    tnx again,
    drcool
I am looking for a service manual for my Kirby G4D vacumn.The number on the vacumn is 7941006690. Sounds like there is something caught in the motor or fan . I am not sure how to take the vacumn apart...
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
http://kirbywhq.powweb.com/manuals/G4/8D4538EC00E93846200D614F7C499B59/G4%20Manual.pdf
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Aug 17, 2011 | Kirby G4 Bagged Upright Vacuum
Model G4D. Drive wheels run in reverse, not forward. If you tighten the 3 torx head screws on the bottom, the wheels don't turn at all.
it means you had a problem with the allignment or the screws has a different thigthness then check the wheels allignment check the starting capacitor maybe it is damage allready replace it.
Mar 04, 2011 | Kirby G4 Bagged Upright Vacuum
Suddenly my kirby g4d is bowing air instead of sucking the air..what do I do
This is usually caused by a plugged lower bag housing. When the machine is turned on, the bag should expand quickly and firmly. If it does not, remove the bag assembly by turning the housing couterclockwise to remove it from the motor unit, and check for debris.
Jan 06, 2011 | Kirby G4 Bagged Upright Vacuum
The foot switch does not turn on the G4D Kirby vacuum cleaner.
Here's a link to a free guide! The switch is available at this site as well...there is a link in the guide to buy one.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps,
Marci
Aug 05, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G4D belt change . haven't changed the belt in years ! not sure who it goes on, or around the the spool housing ??
Changing belt on Kirby is a bit complicated. Kirby Co. just did not make it easy for their customers. You have to be careful when installing the brush roll back. Brush roll end caps have to be put back a certain way. For detailed instructions with pictures go HERE.
Good Luck,
Rocky
Mar 28, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G5
See my troubleshooting guide and from there, you can view my do it yourself guides for fixing your Kirby.
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Aug 26, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G4D vacuum
Could be the a/c cord, a problem with the noozle not pushing the saftey switch, the bag emptor(bottom of outer bag) isn't on the of the way and not engaging the other safety switch. The other is a problem with the motor.
Jun 28, 2008 | Kirby G4 Bagged Upright Vacuum
Help on kirby G4D
here is a link to taking the fan off of the kirby...all the Generation Series Kirbys are the same :)
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
Hope that helps!!!
Apr 05, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
128 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
