Question about Kenmore 63012 Electric Dryer
Kenmore dryer when dryer is turned on it trips the circuit breaker and shuts everything down that is on that same circuit
  • 1,028 Answers
First dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Posted on Sep 18, 2008
Kenmore Series 80 Dryer won't start after Circuit breaker was tripped
A breaker thrown that many times indicates a serious electrical problem. You need to have the problem taken care of by an electrician. You should be worried about the safety of yourself and your family.
That being said, I would guess that breaker has gone bad and needs to be replaced.
Dec 18, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
After power outage dryer will not come on model # 96573220
Hello Edward, Is it possible that the electrical circuit breaker is tripped in your breaker box? Try shutting the breaker off and turn it back on.
Feb 23, 2014 | Kenmore 60172 Electric Commercial Dryer
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Kenmore elite dryer runs for about 3 min. then trips the breakers
The circuit breaker may be tripping because of a fault with the dryer or it may be a fault with the circuit breaker being weak.
From the description you give the circuit breakers trip frequently.
I'd suggest you first try selecting the no heat air fluff cycle and run it to see if the breaker trips. If the circuit breaker doesn't trip in air fluff then there is likely a short in the heating element.
With a clamp-on amp meter you can read the amp draw of the dryer when it is heating. With the motor and element both working you would see approximately 25-26 amperes being drawn. The breaker is rated at 30 amps. If the breaker trips and only 26 amps are being drawn then the breaker is the problem.
Try the air fluff cycle first and see if the breaker will trip. Then with additional details I may be able to help you further.
Jan 05, 2011 | Kenmore Dryers
Dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
Nov 21, 2009 | Kenmore 63942 Dryer
Kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Aug 24, 2009 | Kenmore 62602 Electric Dryer
Dyer not turning at all
Is the dryer getting power? Check to make sure that the circuit breaker hasn't tripped of been turned off. If the breaker has tripped, you may have a short circuit in the dryer unit and you should have the unit check by a qualified technician.
Jul 22, 2009 | Kenmore Dryers
Kenmore Ultra Care Dryer- Electric
Your dryer doesnt have a fuse. Your home breaker panel is the only protection it has..Check your circuit breaker box for a tripped breaker.
Oct 22, 2008 | Kenmore 62602 Electric Dryer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Tripping circuit breaker
if the dryer trips the breaker right away its a problem with the dryer if its after a while its the breaker. call an electrician to make sure the wires are secured tight to the breaker and the breaker is rated correctly. i can almost guarantee its the breaker.
Dec 18, 2006 | Kenmore Elite HE4 Electric Dryer
Kenmore 63012 Electric Dryer Logo
311 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
