Question about Acer Aspire 5500 5570-2609 Laptop
5720Z acer aspire notebook has power light on and another flickering LED but no picture
Normally when i open the lid or press the power button it comes out of sleep mode but this time nothing is happening what could be wrong i tried using control alt del to reboot but nudda from that, what else can i try or do
    Problem Solver:
  • 8 Answers
Hey Rissa
Press the power button until it shutdown and then restart the machine. Press F8 contiuously till it prompt to some option. Choose restore directory......
good luck
zinja
Posted on Sep 17, 2008
I have an acer 5720z that is stuck in Startup repair how can I get it to boot? It's lid was closed while it was powered up and when user tries to reboot normally it will not. When booting in repair mode it...
it seems like you lost part of your windows. the easiest way if you cant get the cd to run is try to rapair off cd. if not, you need to reinstall. always back-up
Apr 29, 2010 | Acer Aspire 5720 Notebook
My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Nov 27, 2009 | Acer Aspire 4520-5582 Notebook
The status lights for my acer aspire 5720z laptop are not working
This problem occur when your laptop for example is drop. To fix it go to Computer Shop or Repair Center and let them the one to fix your laptop. I'm sure it back to normal.
Nov 22, 2009 | Acer Aspire 5720 Notebook
It is a Mod Aspire 5720z. Keyboard jumps all
it is not your keyboard, rather it is your mouse, you always mistakenly press the pad. either try and keep your palm away a little bit or on the mouse setting disable the mouse by locking it with the small button in front in which if you press the blue light infront of the mouse will trun red. good luck
Sep 16, 2009 | Acer Aspire 7110-2069 Notebook
Flashing orange and yellow lights
Most likely your battery is dead.
If you are worried about your HD , the best thing to do would be to power it off.
Remove the battery and see if it will boot on the AC adapter.
If it boots , just get a new battery.
If not you have a motherboard issue and need to call Acer if it is under warranty.
Apr 22, 2009 | Acer Aspire 5003WLMi Notebook
Drivers carte son
i have acer aspire 5720z series notebook i need graphic driver
May 29, 2008 | Acer Computers & Internet
Acer Aspire 5720Z Notebook - Screen flickers, goes blank then comes back on when screen/lid is adjusted
It is most likely the connector between the screen and the motherboard that is loose/failing. I would check that first, before taking it in for repairs..
May 29, 2008 | Acer Aspire 5100 Notebook
It sounds like a loose connection or a snapped dry solder joint leading to the backlight. On notebooks and LCD monitors, the screen consists of a florescent panel behind the screen which shines a light similar to a florescent tube through the screen. From your description, it would appear that something is becoming disconnected there.
A local specialist in flatscreen repairs should be able to fix it if it's nothing too major. Try and find one who has a certification to work with Acer to avoid voiding the warranty. If you live in Ontario, where I live, I can do a search to see if I can locate one (please either use the ask button to contact me directly or leave a comment on this ticket) but I have no details of potential repair locations outside Ontario.
I have the same problem. It happened to me about half a year ago and reinstalling the OS solved it. So it's by no chance a hardware problem. I have a Acer TravelMate 6291. It must be some kind of a software problem, but don't know which one :-(
May 29, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
