Question about Bose Wave Radio
Power Bose model AWR1G1. After 3 day power outage radio will not turn on. Power ouitlet has power and power cord is firmly in place. Will not turn on using on/off button or remote. Advise please. Sherman White
    President:
  • 2,761 Answers
There's a line fuse on a circuit board inside the radio. CAUTION: disconnect the set from its power source before you open it up or start poking around inside it. If you're lucky, all you will need is a simple fuse replacement. The sets are, however, notorious for "blowing" power transformers. If the fuse is not the problem, you will likely need to send the set to Bose for repair. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Posted on May 21, 2009
How do I improve my reception on a Bos Wave Radio with single CD player
The Bose uses its power cord as an antenna. The cord has to be stretched out (not coiled) to pick up stations. It also helps if it's oriented the right way -- try changing the direction (having the cord running east to west, say, instead of north to south). Moving the radio and the power cord closer to a window can help, too, especially in a commercial building. These structures often have a steel frame which can block radio signals. If all the above fail, your best bet is to buy an indoor FM antenna, which can be as simple as a piece of wire made into a dipole antenna or as fancy as one of the Terk mini-towers with built-in amp. Bose sells one for their radio, though it's kind of expensive for a simple length of wire. You can get the same thing from Radio Shack, but if you do, be sure to pick up their adapter (catalog 278-257) to plug it into the non-standard Bose jack. All together you'll spend half what Bose wants. Move it around like you did the power cord and you should see a big improvement.
Aug 05, 2014 | Bose Wave Radio / Cd With Remote model...
How do i change the memory back up battery?
Hello
You can replace the battery without loosing its memory. Follow these instructions. Battery must be changed as fast as you can. So read well and they do the work.
o Bose radio uses a standard nine-volt battery that serves as a backup for the memory and alarm when it's unplugged or when the power is off. It will power these functions for up to three days. Using the radio without the battery won't damage it, but the memory won't be backed up. The battery does not provide enough power for normal operation, including the lighted display.
To install a battery, turn the radio over. Push on the arrow on the battery chamber cover and move it aside. Match the terminals on the battery with their opposites inside the chamber, and push the battery securely into place. Close the cover and return the radio to an upright position.
Connect the power cord to the jack on the back of the radio. The flat side of the connector must line up with the flat side of the jack. Since the power cord contains the FM antenna, uncoil the cord for the best reception. Plug the power cord into a standard electrical outlet.
An FM cable connector is on the back of the radio. Contact your cable company for help in setting up your connection. When you set it up, be sure to use a splitter that separates the FM signal from the TV signal so that the TV signal won't be transmitted to your radio.
If your remote is slotted on the back, press the tip of a pen into the opening and push the battery chamber cover to the side. If there's no slot, push the tab to one side with your finger and open the chamber cover. Use only a lithium battery size CR 2032 or DL 2032. Place the battery into the chamber with the plus sign face-up. Push the chamber cover closed and it will lock.
Mar 18, 2011 | Bose Wave Radio
After a power outage, my Bose radio went to military time. I've tried to re-start it by unplugging, re-unplugging, etc. Help!
To switch between 12hr and 24hr format:
1) Turn your Wave Radio off
2) Press and hold "Clock Set"
3) Press "On/Off" to switch between 12hr or 24hr format.
Dec 27, 2010 | Bose Wave Radio
Need new power cord for Bose Wave model AWR1-!W
http://audiosaler.com/bose-wave-radio-model-awr1-1w-w-remote-power-cord
Just follow this link immediately.
Dec 03, 2010 | Audio Players & Recorders
Bose radio will not turn on. I have a Bose Wave radio, model AWR1-1W, D.O.M. 980305, that will not turn on. I've verified that there is power to the radio (checked outlet plug of cord). I've looked...
I have the same issue with the same model. I found an open primary winding in the large transformer inside the unit. Now the problem is finding somewhere to buy the transformer...
Sep 19, 2010 | Bose Wave Radio
Alarms will not work
Hi. Often following a power outage there is a power surge when the power is restored. If you do not have your Bose protected by plugging it into a surge protector, an internal fuse will blow to protect the rest of the radio. Once that fuse is replaced you will be back up and running. J.
Jul 09, 2010 | Bose Wave Radio II
We can not turn on or charge the Bose. Is there a way to try a new power cord to see if that is the issue?
Which model of the Wave radio is this ? If it is using a 9V battery you might want to check the pcb for some discoloration at the Q4 transistor.
If you have a meter available confirm if it is good or bad. Bose has a
problem with this transistor part# 2SC3792 that is undersized for its
purpose. This transistor provides the 5V for the IC and without the 5V
your radio will look as if it is totally dead with no display and you cannot
turn it on. Typically it is only Q4 that is shorted (0-3 ohms) between the outside (emitter and base) pins. Replacing it with the same part will
bring the radio back to life. Bose recommends a beefier part -
2SD438F-MP-E but it is very hard to obtain. I have used a 2SC2655
without any problem and it is much easier to get.
Jun 01, 2010 | Bose Wave Radio
My Bose Wave CD Radio has no power. Will not turn on. dead. Checked the power cord and supply, it is good. Is there an internal fuse?
Yes - although Bose doesn't really publicize the fact, there is an internal line fuse in each Wave. Location varies by model and date of manufacture, but the fuse is easy to spot once you open the radio case.
Bill B
Apr 10, 2010 | Bose Wave Radio
Can a Bose radio get fixed after a power surge?
YES IT CAN UNPLUG THE RADIO ..OPEN IT UP LOOK @ WERE THE POWER CORD COMES INTO THE RADIO SEE HOW BAD IT IS >>>IF IT IS ALL BURNT UP YOU HAVE TO GET AN IDEAR HOW MUCH A REPAIR PLACE WILL WANT>>>>>>>>BUT IT MAY ONLY BE A FUSE IN SIDE YOU MAY GET LUCKY>>>>>>>>>YOU CAN EVEN FIX THAT YOUR SELF WITH A SOLDERING IRON FROM RADIO SHACK OPEN IT UP SEE WHATS GOING ON IN SIDE MAKE SURE POWER IS UP PLUGGED GOOD LUCK
Feb 20, 2009 | Bose Wave Radio
I have a problem with time display on my Bose CD/Clock Radio.
I found the answer on the Bose website in the manual for the radio. While the radio is on, hold down Alarm Setup and preset 1 at the same time. That will set it so the clock displays. If you do the same thing but hold down preset button 2, that will display the radio info all the time.
Nov 23, 2008 | Bose Wave Radio
Bose Wave Radio Logo
311 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
