First thing I tried to do was to install the drivers that came into the CD didn't work, just using mydvd9 the import/aqcuire option I could have some noise signal, but couldn't find a way to select channels and hanged after a while. This is too trickier, I thought, it should be a way to used quickplay and other applications.
I couldn't get anything from HP site so investigating I found the following.
1) Had to upgrade quickplay to latest version (is pretty cool btw)
2) The card internally is a Hauppage and found that is actually the HVR1500
http://www.hauppauge.com/site/products/data_hvr1500.html.
Drivers + application can be downloaded at
http://www.hauppauge.com/site/support/support_hvr1250.html
3) After upgrading quickplay and installing drivers and application from hauppage, Quick play had additionally an hp digital tv tuner entry, but here in canada there is no digital signal transmitted through antenna.
4) I have reinstalled manually the drivers that came in the CD, but from the c:\swsetup\HP Digital tv tuner folder
5) After this I had at quickplay a second source "Hp Analog Tv tuner" which allowed me to caputure the regular air signal and wintv worked as well
I'm sure that I did some redundant steps, but it worked and now can I have everything working (quickplay, wintv, digital, analog signals)
Hope this helps and btw I haev uploaded the manuals for thouse who can't get it, since HP doesn't have them in the website.
Cheers
Alejandro
same deal my tuner will not work with quickplay 3.7
