Question about Kitchen Ranges
Oven won't stay alight . has never worked from new . have checked all thermocouple connections all seem's well. probe is tight and in correct position.
  • daveebecker Nov 11, 2008
    Mine will pre-heat most of the time, but sometimes after pre-heat it won't heat back up.
  • 1,543 Answers
To post a more specific solution you need to have the model number, but with the info you have given, I'm guessing that you have hooked the range up to LP gas and the range was not fully converted from natural to LP. If all burners burn nice, whomever converted the range may have missed one step. Many ranges with pilot lights have a small slot head screw behind the oven temp set knob which turns one way for natural, one way for LP.
Posted on Sep 16, 2008
Burners n broiler lite up fine, oven will not .... pilot out?
Does it have electronic ignition or pilot. You don't say. Check the thermocouple. That is usually why most ovens fail even when overhead broiler works. The Thermocouple is a probe that heats up either by pilot or igniter and turns the gas on when it reaches the proper temperature. You can sometime take a little steel wool and clean off the probe..sometimes that will do it. Make certain you are cleaning the thermocouple and not the thermostat probe.. Thermocouples are right near the burner itself. If that does not work you will need a new one.. some screw out and can be replaced.. others may be sealed to the gas manifold. You will then have to call a repair man to replace it.
Mar 10, 2015 | Kitchen Ranges
How to fix problems with hob not staying alight on rangemaster lpg
If you are holding the knob in for a good few seconds and finding that it still goes out, the thermocouple has failed on that hob. The thermocouple is the metal spike sticking up when you take the ceramic plate and carrier off each ring. First check that the ring pieces are correctly sitting on the cooker, but if they are you will need that thermocouple replacing.
Feb 26, 2015 | Rangemaster 110 (Gas) Kitchen Range
Superser gas heater lights but wont stay alight new thermocouple fitted
The tip of the thermocouple needs to be moved closer to the pilot flame.
Feb 02, 2015 | Heating & Cooling
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
Pilot l.ight will not stay lit
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Oct 20, 2010 | Whirlpool Water Heaters
I have an outdoor gas LPG heater where the pilot gas light will light but will not stay alight to fire up the heater! Have cleaned & adjusted the themo-couple senser but no joy
Remove the thermocouple from the end opposite to the flame, usually an 8mm nut. Give the little nodule at the end of the copper line a quick shine up with some wire wool (not to aggressive, its just to make a good electrical connection). Tighten it back up 1/4 turn past hand tight only. If that still doesnt work and the falme is nicely in the tip of the flame you will need to replace the thermocouple. Pretty simple job and they are usually about $30. Thermocouples do wear out.
Aug 08, 2010 | Heating & Cooling
Describe what could be the problem if my oven will light but not stay alight once I release the gas button
That could be one of 3 things: The thermocouple could be bad, the hole that the thermocouple screws into could have corrosion and causing a loss of electrical current to the safety magnet. Or the safety magnet itself is bad. The thermocouple when heated generates electricity. The magnet inside the valve is powered by the thermocouple. If the pilot light goes out the magne looses energy and the spring attached to it shuts off the flow of gas. Pretty clever ain't it?
Jan 20, 2010 | Ovens
Hi When I try to light the gas oven, it will light but as soon as I release the button the flame goes out
Are you giving the thermocouple time to warm up?
You have to hold the oven knob in for a while to warm the thermocouple before the oven will stay alight. If you are doing this then the thermocouple needs replacing.
See my other posts for a link and price as it was at that time.
Dec 11, 2009 | New World 50GSO Gas Kitchen Range
Kitchen Ranges Logo
228 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
