Question about Microwave Ovens
Bulb has blown in goodmans me21s microwave how do i replace it
  • Microwave Ovens Master
  • 9,086 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
The microwave is working, but the light doesn't come on. can it be changed if blown?
yes. bulbs of microwave can be replaced.
Mention your brand/model/size and someone can help identify the right bulb and procedure to replace yourself.
See below an example Microwave Repair Replacing the Internal Light Bulb 40W Whirlpool Part...
Apr 15, 2016 | Microwave Ovens
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
Light doesn't go off and microwave doesn't work
follow this steps and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 14, 2013 | Sharp R305KS Microwave Oven
Interior light bulb burned out
make this test and fix it. GOD BLESS YOU
Oct 31, 2013 | Samsung SMH8165STE Microwave Oven
Light bulb
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    Need user's instructions manual for Electrolux microwave oven model ME21S
    Well you may please follow the link below to get your manual -
    http://www.electrolux-ui.com/UM%5Cmaster.nsf/SearchFrame?OpenFrameSet
    Good Luck!!
    Thanks for using FixYa!!
    Nov 23, 2010 | Electrolux Microwave Ovens
    Bulb blown. How do I change it?
    Hello there :
    first you will need to remove all of the screws off the back edges and the sides next turn over the microwave over and there will be 6 or 8 screws that are on the bottom edges remove them now turn over the microwave and using a flat tip screwdriver look at the seam and you can use the screwdriver to get the cover to start moving towards the back andd then once it is loose it will lift off
    Now you will see the bulb towards the fromnt of the microwave simply replace the bulb and test it the microwave if it works reassemble the microwave and you are done ok ?
    I hope this is very helpful for you
    Best regards Michael
    Dec 03, 2009 | Zanussi ZMC30STQX Convection Microwave...
    Microwave Ovens Logo
    113 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
