Question about Grilling
Jenn air grill
Burner knobs getting real hot on my jenn air grill
  • willi067 Apr 06, 2009
    knobs have melted solid
  • Grilling Master
  • 19,396 Answers
You should test the wiring to see if there is any short that is causing the overheating.
If one knob only is getting hot, then the knob is probably faulty and need to be replaced.
I the all knobs are overheating because of heat coming from the grill, then is a bad heat insulation problem, better to call the service number listed on the owner manual and discuss the problem with Jenn Air in this case.
Here you find replacement parts for your model, in case you need to replace a knob.
Posted on Sep 16, 2008
How do I remove the burner knob off my jenn-air gas grill 720-0061
They should just pull off. They may seat tight and may need some wd40 to lubricate them.
Feb 12, 2017 | Jenn-Air Grilling
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
The center burner knob on my jenn-air grill gets hot, the far left knob is off, and the outside cover is showing burning residue
From what you have described, it sounds like the offending burner tube is partially clogged and causing the burner flames for back fire and heat the control panel. To solve this, you will need to remove the burner and clean it and it's venturi valve thoroughly. You can accomplish this with a soft bristle brash grill brush or an old tooth brush.
Hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Sep 04, 2011 | Jenn-Air Grilling
I have a Jenn-Air gas grill model #720-0061-LP it has 3 brass burners and a rotisserie burner on the back wall. the flame from the middle burner is shooting back into the knob causing issues with the...
I have had the same problem before with same exact grill. The burners get clogged and the gas pressure backs up. I have had this actually split a gas valve and the plastic electronic igniters do not have a chance withe the head. Call nexgrill and get all new burners under warranty. This will solve the problem for a while. The latest burners that I received in Aug 2010 are 1/2 inch shorter and may solve this problem. You may want to buy new gas valves since the excess heat in this area may have damaged the valve. Since 2004, I am on my 5th set of burners, 2nd set of gas valves and 3rd electronic ignitor. May just recycle grill and get a Weber or go with charcoal.
May 09, 2010 | Jenn-Air JLG7130A
Flare behind temperature knobs on jenn-air gas grill
This seems to be a problem for most Jenn-Air users. The burners are defective, rusted or clogged and allowing the flame to "back up." You most likely have a melted electronic ignitor as well as gas valve damage. The new burners that I received this week for my model 720-0061-LP are 1/2 inch shorter than previous versions. Time will tell if this fixed the problem. I would call Nexgrill and get all new burners and inspect the gas valve area for damage. Since 2004, I am on my 5th set of burners, glad they were free since I have a lifetime warranty on my model.
Apr 17, 2010 | Grilling
The grill never gets hot enough even with 3 burners lite.
Turn on one burner to start, once it is on, turn on a second burner. If the flame gets lower with two burners on, you need to replace your regulator.
Dec 18, 2009 | Jenn-Air Grilling
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
I have a Jenn-Air grill with three burners. When I light the first two burners, they light fine, when I light the third burner, the flames on all three burners get real weak and the grill will not go...
Screwy new tank has safety feature: so...
remove the tank and clear the the lines.then reinstall the tank and crack open the vave just a hair. Retry. Seen it.
Sep 14, 2009 | Jenn-Air JLG7130A
How do I adjust the flame to burn hotter or more.
There are adjustment screw at the end of the burner tubes that allow more or less air to enter the burners. try opening or closing these screws
Jun 01, 2009 | Jenn-Air JLG7130A
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Grilling Logo
288 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
