Question about Maytag Washing Machines
I HAVE A NEPTUNE STACKABLE WASHER AND I AM HAVING PROBLEMS WITH THE FABRIC SOFTNER DRAING OUT. IT STAYS IN THE LITTLE RECTANGLE CONTAINER. WHAT CAN I DO TO SOLVE THIS PROBLEM?
  • 39 Answers
Hi ggdude
It sounds like the hose is blocked. here is how to get it un blocked. first open the door and there are 4 philps screws take those out and take the door off. the front panel should come off now. then you will see the 2 black hoses one for fabric softner and one for bleach. use a 1/4 inch nut driver and remove the clamp on the hose and use a coat hanger to clean out the hose and it should work again.
hope this helped
brent
Posted on Sep 16, 2008
I have a frontload. The bleach is not dispensing. I have taken it apart and cleaned it but that did not seem to help. I do not use fabric softner so not sure if that side works
i have a maytag neptune 6500. we have tried both the bleach and the fabric softner. neither work. we've tried selecting every option on the machine, cleaning it, using hot water instead of warm; nothing is working.
i packed up the manual in the process of moving so i can't get to it right now. i'm surprised there's no solution yet online!
sorry this isn't a solution, but more problems.
Jun 25, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune tl fav6800aww wont dispense fabric softner
Test mode? Do you mean Service Mode and you turn on the solenoid for the water valve to divert water to the Fabric dispenser reservoir and it is flushed in Service Mode?
See if this solution will help with your trouble shooting.
Let me know if I can help……Rich
Apr 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
What does the code suds mean on my maytag neptune washer
sud's ( like to much soap ) this causes the machine to shut down . mix some downey of fabric softner in a quart of water . pour it in tank . let set over night . and try again . fabric softner will get rid of suds or at least reduce them . it will probably work .. mm
Dec 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune washer is dispensing fabric softner during wash cycle! help!
not good. the board usually tells the dispenser to activate and send water to you fabric softner, ive seen two different problems on the maytags, your water valve could be bad or clogged or the board is bad.
Sep 17, 2009 | Maytag Washing Machines
FABRIC SOFTNER TRAY STAYS FULL AND IS NOT RINSEING OUT
HiYa dh1200s
The softener tray needs to be cleaned out or the sensor for this replaced.
Yes, not enough water entering machine so not enough water to rinse out the softner
Please leave a good rating before you sign off.
Mar 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
My neptune washer will not drain the fabric softner container
This is joyce
I have advice for you check the siphon cap to see if its twisted reposition cap.
thanks
joyce
Jan 17, 2009 | Maytag MAH6500 Neptune Front Loading...
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Softner will not dispense
not draining from compartment is usually caused by a blockage it compartmnet, try pooring boiling water into the compartment, this will usually resolve problem
Dec 08, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
