3210 paper wil not feed in the printer it not jam it just will not feed
    Genius:
  • 1,550 Answers
  • Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
  • With the printer off, check for any obstructions such as torn paper or foreign objects.
If there is no torn paper or any obstruction then follow this
  • Place 20 sheets of paper in the printer ensuring none of the paper is torn .
  • Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
  • Try to feed paper manually .
If your problem is not solved yet then follow this
  • Uninstall the printer driver and restart the computer.
  • Re-install the printer driver
SAM ANDERSON
Posted on Sep 16, 2008
My HP 3210 the paper not feeding
I have exactly same problem, is it an automtic "buy a new one" syndrome
Feb 02, 2010 | HP Photosmart 3210 Printer
Paper Jam, when there isn't a paper jam!
just remove thr paper outer tray and see if there is any part of paper is there.
Sep 08, 2009 | HP Photosmart 3210 Printer
Screen blank; doesn't print; can't get the lid in
hi,
this is the paper feed roller problem.
Pls clean it properly using moist cotton or with spirit or petrol.clean all roller with it .
it will resolve your paper feed problem .if not then it is assembly problem. contact to any printer expert
Aug 18, 2009 | HP Photosmart 3210 All-In-One InkJet...
Paper has jammed at the back of the printer, and I can't see a way to get it out.
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 25, 2009 | HP Photosmart 3210 Printer
Only on Quicken to 3210 all-in-one printer. Paper starts to feed then indicates paper jam, wait long enough and paper feeds with crinkle and no print.
I would check the paper path on the printer where it is crinkling the paper. More than likely there is some small piece of paper or something that is causing it. Does it only do this out of quicken? I wouldn't think so if the paper comes out damaged....
Feb 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Manually feeding paper
Even if manual feeding is an option the paper must be able to fit the paper tray in order to feed it through the printer.
Jan 20, 2009 | HP Photosmart 3210 Printer
Photosmart 3210 all in one printer
Turn the printer around and open the door you will see paper jam.
Jun 30, 2008 | HP Photosmart 3210 Printer
Paper tray does not feed at all or may jam several papers
The rubber wheels that feed the paper in can be too soft to grip the paper.
After a long dicussion with the help desk, HP supplied me with a special Paper Feed Cleaning Kit for the 3200 series. This comprises a scraper device that you insert into the paper feeder, and a driver CD. I had to use it three times, Now everything woerk fine.
Jun 19, 2008 | HP Photosmart 3210 Printer
Paper jam
I tried the Cleaning Kit HP sent me. At the time they didn't mention that it required a direct USB hookup rather than the Network setup I was using.
Another user suggested using Lighter Fluid sprayed on the defective (too hard) paper feed wheels. Crazy solution? Lighter Fluid is mainly Naptha which the user claims softens rubber.
I tried it last night and waited for the fluid to evaporate before plugging the printer in. I really expected the darned thing to go up in flames so I had a pot of water and a blanket nearby as a fire precaution.
Much to my surprise .. the PSC 3210 has been feeding sheets perfectly for the past two days! This is after sitting in a HOT attic abandoned for over a year! I had to replace one ink cartridge which had dried out completely.
I don't know how long this "fix" will continue working but Lighter Fluid is cheap. The PSC 3210 is a quality printer WHEN it prints. It's too bad HP created so much bad will in its customer base because of defective rubber paper feed wheels. I've avoided purchasing HP products for two years now and have warned others to stay away because of this fault with customer service. Instead of replacing the defective rollers in my original printer, they exchanged the printer for a refurbished printer with the same defective rollers!
Mar 31, 2008 | HP Photosmart 3210 Printer
Paper feed problem
Check all this-----
1.check the printer paper feed roller jam.
2.check the paper sensor, It is working or not.
3.check the paper tray(clean it)
4.service the printer, (If possible).
Goodluck
Mar 10, 2008 | HP Photosmart 3210 Printer
Computers & Internet Logo
91 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
