Question about Whirlpool GGQ8831L Gas Dryer
Drum won't turn
I was cleaning the drum and turning it by hand. I heard a noise and now the drum does not turn. I looked at the belt and it is loose around the drum. Is the belt just off? If not, then what?
  • 5 more comments
  • boys2-8 Sep 16, 2008
    Thanks so much! I have already checked-the belt is not broken
    No, I don't have the manual. I am searching the internet to find it. Do you have some quick tips that I can use?
    It is an Ultimate Care II by Whirlpool
    I have not looked that far. I am at work right now, so I won't be able to look at it until tonight. I can get back to you later.
  • boys2-8 Sep 18, 2008
    Okay, stand up, hands in the air and shout with me, "I DID IT, I DID IT!!"
    Thank you so much for all of your help.  I had a do it yourself book that guided me through the process of fixing it, but you led me into the right direction.  Thank you so much!!!
    No, thank you! I saved myself money, plus I found like $5 in change! BONUS!!
  • lovechri2 Nov 24, 2008
    My dryer will heat, but it will not turn. It might be the belt, but i can't find the belt. Where is it!
  • 958 Answers
It came off the tensioner or it is broke. pull the belt and see if it is not broke. if it is still loose around the drum, then it just came off the tensioner.
look at the manual on how to put back the belt with the tensioner.
tnx 4 using fixya,
drcool
Posted on Sep 16, 2008
  • 5 more comments
  • francis rivero Sep 16, 2008
    ok..then just install back the belt.
    do u know how ?
    drcool
    what make? it is just a little tricky but i think you can do it. i will guide you.
    drcool
    have u seen the tensioner?..does it has a wheel or just a shiny metal which is curve like a half round metal?
    ic, ok..probably catch you again 2morrow..will be sleeping now. use the ask me button so that i can continue.
    tnx 4 using fixya,
    drcool
  • francis rivero Sep 18, 2008
    hi boys2-8,
    so "YOU DID IT, YOU DID IT !" glad that you fixed it. can i just ask a favor?
    Ratings are just as important to us as answering your questions, may i just request for a Fixya rate to boost my morale and help more people here at fixya.
    tnx a lot,
    drcool
    hello again boys2-8,
    thank you very much for the rating.
    i appreciate it.
    drcool
    hahaha..wow. that's great.
    i'm glad i was able to help.
    cheers,
    drcool
While cleaning the inside drum and turned the drum by hand. She heard a "loud noise" and will not turn. The control panel will come on andselect the mode, but when start is pushed nothing happens.
When you rotated to drum you caused to belt to pop off the pulley .it has a safety switch so it won't run if belt breaks . With unit unplugged remove top than control panel than front panel to access bottom to put belt back on just enough room for hands to fix inside
Mar 26, 2016 | Samsung DV218AEW Electric Dryer
My dryer WGD96HEAW1 makes vibrating and grinding noise after heats up, not in the beginning when turned on.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Feb 28, 2016 | Dryers
2yr old maytag maxima dryer gets louder and louder after run 30min. prob. repeats after cool down and running again. Vent is clean new pipe, no error codes. Sounds like a surging vibration.
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 06, 2015 | Maytag Dryers
I have a candy condenser gcc58onb it is making a terrible noise when it turns the drum turn s what is this?
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Feb 21, 2015 | Candy Dryers
My dryer MAKES A lOUD THUMPING NOISE IN THE DRUM. BELTS ARE NOT BROKE
DRYER MAKES NOISES.
The blower:
The bearings:
Oct 05, 2014 | Dryers
Drum turns but sounds like a small metal object, possibly a screw, banging around inside . Continued to use and now sound is much louder and sounds like a bigger object.
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The belt loose or worn can make funny noises
Jun 27, 2014 | General Electric Profile DPSR610EGWT 7.0...
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
Drum of maytag dryer does not turn it was working,I turned it by hand,and I heard a metalic noise and now it does not turn
It sounds like the belt has jumped off the pulleys, or possibly it has broken. You will need to take the dryer apart and remove the drum to get a new belt on.
Jul 26, 2011 | Dryers
My washer mad three loud thumps and then would not spin at all. It will pump the water out but will not spin. Do you think it is the belt. Thanks helyn
The belt might have slipped off the pulley. But when you mention that you heard loud thumps before it stopped spinning is a sign that something else might have gone wrong with your machine. With the washer turned off, turn the wash drum by hand and listen for any noises. It should turn quietly without any kind of thumping noises. Also look how the drum turns. It should turn smoothly and not wobble as it turns. If it wobbles or makes thumpiing noises, it means that the support arms are broken.
Reparing the support arms is an expensive repair, unless it is still under warranty, it not worth fixing. Get a few estimates before deciding to repair or replace it.
Feb 08, 2011 | Frigidaire ATF6000ES Front Load Washer
The Dryer drum has stoped turning in the clockwise direction and the motor hums when you try to start the dryer. heard a squelling noise before it quit. I have taken the back off and cleaned the vent...
next time send model number,if you looked and nothing was in the blower wheel and you can turn the drum by hand it sounds like you have a bad motor,take the belt off and pull the drum,stick a piece of wirer in the door switch harness, there should be three openings stick it in the two outside holes,the middle is the ground and see if the motor will spin by itself,also check the pulley but like i said sounds like the motor is bad
Feb 11, 2010 | Kenmore Dryers
Whirlpool GGQ8831L Gas Dryer Logo
136 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
