Question about Akai LCT2715 27 in. LCD Television
Akai LCT 2715
I bought this television from sam's club and I am experiening the popping sound and the blinking red light. How do I fix
  • Akai Master
  • 5,568 Answers
This problem is with fair certainty the power supply.
Modern power supplies are designed to shut down if the current drawn exceeds the design level which indicates that something the supply services or the supply itself has died.
If you are adventurous, you might pull the plug on the set, gain access to the innards, and with good light, inspect any boards inside. If you see one that has few ICs but many more larger discrete parts, this will be the power supply.
You are looking for components called electrolytic capacitors that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is also still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many (not all) will show signs of pregnancy when they fail, bulging unnaturally when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
Some also have a date code (rarer) that will look like four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006. The caps made between those years may be bad when new.
The larger caps will probably be OK since the failure is likely related to functions other than brute-force filtering. A pretty good 'rule of thumb' is to replace any caps you see bulging that are 100 uFd or less. If you don't mind a few nickels more, insist on 'low ESR' capacitors.
If you choose to replace these yourself, you will need a quality soldering iron with a small, preferably iron-plated tip, rosin core solder and a sponge which when wetted is used to frequently wipe oxidized solder from the tip this should be kept bright and clean and fresh tinning will keep it that way.
You should also buy some solder 'wick' with the iron; this is used to place on the solder you wish to remove and then heated with the iron. Properly used. the wick will absorb nearly all of the solder from the lands from which you wish to remove a component.
A good source for any of these things is http://www.mouser.com/  They have a huge inventory of parts, fair prices and no minimum billing.
Posted on Sep 16, 2008
I fixed the power supply but don't have a
akai LCT2715 keeps shutting off or making a loud screaming noise that can only be turned off by shutting it down at the the tv
Dec 21, 2009 | Akai LCT2715 27 in. LCD Television
I have a lct 2715 not too long ago the screen went black and the power light blinks yellow
The failure with your LCD might be due to defective capacitors in the power supply. These parts become defective due to excessive heat and fail prematurely If you are able to DIY, you can check the picture to see how defective capacitors look like.901ae86.jpg
Oct 01, 2009 | Akai LCT2715 27 in. LCD Television
Akai lct 2070 tv switch does not turn on tv-no sound-no tv
Most failures on this TV are due to defective power supplies. If the TV does not turn ON, you should replace the power supply.
Check this website to buy the power supply adapter and hopefully that should fix the TV.
Jan 21, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
TV will not turn on from Stand By mode
if you are comfortable taking the back cover off, do it and visually inspect a cylindrical shaped components on the power supply unit... if you can send a picture please do s69joe@hotmail.com
Dec 08, 2008 | Akai LCT2715 27 in. LCD Television
Lcd akai 2715 blinking red light
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 19, 2008 | Akai LCT2715 27 in. LCD Television
AKAI LCT 2715:
Its busted. Try resetting it as a last resort, unplug the AC, wait 1 minute, then plug back in. If that doesn't work, its in need of professional service.
Jul 17, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT 2701 TD - Red Blinking lIngt
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
Jul 08, 2008 | Akai LCT2701TD Television
Akai won't turn on
my tv burned up after 1 month it kinda did what yours is doing and we had to pay fo shipping and it was almost 100.00 dollars, it has been 6 months and we have not got are tv back and they dont know when we will get it so dont send it to these idots they dont car. im in the army and told them this i will be going to irac and cant get my tv. they said send it some where else. so if i where you take it back were you got it
Jan 17, 2008 | Akai LCT3285TA 32 in. LCD Television
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai LCT2716 Flat Panel TV
I HAVE A RED BLINKING LIGHT ON MY TV ANY IDEA'S HOW TO FIX?
Sep 13, 2007 | Akai LCT2716 27 in. LCD Television
Akai LCT2715 27 in. LCD Television Logo
157 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
