Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
GE Side by Side not defrosting
My refrigerator/freezer does not defrost. I had someone look at it and he thought it needed a defrost timer which is built into the mainboard. So, he replaced the whole main board. It is still doing the same thing. The "snow" collects on the back freezer wall. When it gets about 1 in thick both the freezer and refrigerator stop cooling. If I unplug it and let it defrost (usually overnight) and plug it back up it will work fine for about 2 weeks and once the "snow" builds up again we have the same problem. Again, the whole mainboard has been replaced. Do you have any other suggestions?
  • littlegiant0 Sep 16, 2008
    drcool 299, thank you for the input. Where are the defrost heater and bi-metal located? Is the defrost heat not a part of th mainboard? Are these easy to replace? Expensive? I've already spent $120.00 on the mainboard. Thanks.
    littlegianto
  • 958 Answers
Hello little G,
there are two more components that u need to check,
the defrost heater. ( heating element ) - it should have continuity ( low resistance )
and the bi-metal. ( should have continuity while the coil is covered with ice.) check it before you unplug the fridge.
the main board that you replaced is just the controller for defrosting.
tnx 4 using fixya,
drcool
Posted on Sep 16, 2008
  • 1 more comment
  • francis rivero Sep 16, 2008
    they are both in the evaporator. you have to remove the back plate of the freezer section while it is frosted up in order to check the bi-metal. the bi-metal is on the upper part of the evaporator coil, it is usually round and has two wires attached to it. check it for continuity but DO NUT TAKE IT OFF the coil. it needs to be frozen so that you can test if it has continuity. if it has then it is ok.
    the heating element could be glass type or black metal type heater.
    they could either be a one pc "U " shape metal heater running from the top of the left side going down at the bottom and up on the other side.
    test it for resistance. it should have low resistance since it is a heating element.
    go from there,
    tnx again,
    drcool
    the heater could also be a two piece glass type heater located at the middle of the evaporator coil and at the bottom part. they are connected in series so test them both for continuity.
    tnx again,
    drcool
    they are easy to replace and the bi-metal im sure would be cheap but not sure about the heating element. got to sleep now so we'll just continue tomorrow,
    tnx,
    drcool
Ge frig does not freeze on freezer side
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Need help finding the defrost timer in GE fridge !!
frigidaire Model frs22zrg Water leaking into the the dispenser (where you put the glass. Also the ice dispenser become iced and where the ice comes out.
The moisture is inside of the freezer part, may need a time or the heating coil is not working.
Aug 08, 2009 | GE GSS25SGMBS Side by Side Refrigerator
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not keeping cold and forming icicles along wall
It may just be a defrost timer. Search online for information. There is plenty to be had. Check with the website of GE for a parts breakdown or your manual if you still have it for the location of the defrost timer. You can turn it manually so it goes into defrost. Does the unit seem to be running all the time and never shuts off? If so that timer could be stuck in the cool mode and the evaporator is freezing up solid so air wont flow over it to properly cool. I've had two refrigerators I've had to repair that had defrost timer problems. One stuck in the defrost cycle and wouldn't turn on to cool, the other did what you are describing. It stuck in the cool cycle and wouldn't defrost you may need to manually bypass the cooling cycle several times to allow it to completely defrost. Usually it cycles in cool from 6,8 or ten hours and only stays in defrost for over twenty minutes. That should defrost it and allow it to start cooling again. If you notice that frost has disappeared inside on the wall replace the timer.
May 22, 2009 | GE Monogram Side by Side Refrigerator
Kenmore Side by side Model #53271... not cold
you have a defrost problem in the freezer,it is one or more of 4 things,freezer fan,defrost timer,defrost bimetal switch or defrost heater,check all until you find your bad part-mike
Jan 07, 2009 | Kenmore 53262 / 53264 / 53269 Side by Side...
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Oct 20, 2007 | GE Monogram ZICS360NRRH C... Bottom...
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
240 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
