Question about Sony STR-D665 Receiver
Sony STR-D665 I just bought a Sony STR-D665 Receiver from a garage sale. It worked fine for the first couple of days and then it just stopped working. The word "Protected" would show up on the screen and it would lock down allowing me only the option of turning on and off the receiver. If there are any easy fixes to this problem I would greatly appreciate the help. Thanks!
  • Sony Master
  • 19,396 Answers
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
My Sony STR DE875 receiver stops working (playing a FM radio station) after operating just fine. After a few minutes, the receiver produces sounds again. This receiver is on most of the day and the...
It's not a short - it's more like a cold solder connection. Poke the circuit board with a non-conductive tools and locate the open solder connection while the unit is powered up.
Dec 26, 2010 | Audio Players & Recorders
I can't pair D665 with T-mobile G1
HI,
Hi, first you have to enable the Bluetooth to scanning mode,
To do this, press and hold the power button continously for 10 seconds, you may have a stable LED, this shows that its in discoverable mode, Now perform scanning and you may get your device and you can pair and make it work
Please rate this solution if this solves your issue, or leave me comment ill help further
RNJ VINODKUMAR
Dec 17, 2009 | Sony STR-D665 Receiver
Sony GX57ES FM/AM Receiver does not come on
MINE DOES THE SAME THING. I JUST USE THE REMOTE (or a universal remote).
Jun 25, 2009 | Sony STR-D665 Receiver
I have a STR-D665 FM-AM Reciever. It worked fine before I moved but now after about 5 minutes of play it will click and flash "Protect". Is there a way to reset this? Do I have something wired incorrectly?
When you moved did you put somethink on it so that it does not have good ventillation through itself to keep it from overheating? Or set it down in a way that it does not have ventilation room under it? Some papers set on top of it or a pillow under it would block good cooling ventilation through it.
Nov 28, 2008 | Sony STR-D665 Receiver
"Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
Getting Surround to work
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Marc
Sep 07, 2008 | Sony STR-D665 Receiver
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
Sony STR - D665
Hi Spike, The first thing I would try is to reset the system. Turn off the receiver and then hold down the power button for 5 seconds. "Enter to clear all" will appear in the display. Press enter and "Memory Cleared" should appear in the display. You are now back to factory settings. If this does not work, try checking the fuse. Take the two screws off from the back top of the unit, and the two screws on each side of the unit, and pull the cover off from the back. You will see the fuse in the back right side (if you are looking at it from the rear) Pull the fuse out and see if the wire is broken. HOPEFULLY one of these solutions will fix the problem. Please let me know how it works. Best regards, nightdiver
May 29, 2006 | Sony STR-D665 Receiver
1,066 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
