Question about StarTech.com StarView SV431USB 4-port KVM Switch
Problem with KVM switch and Vista
I am trying to use 2 pcs with a single monitor, mouse, and keyboard. The first is a ThinkPad T60 laptop running XP Pro. The other is a Dell Inspiron desktop running Vista Home. The switch is a Starview SV231USB. Both machines are using USB for the mouse & keyboard. The XP machine is working just fine, but the Vista machine doesn't recognize the mouse or keyboard. The switch also allows for the sharing of 1 other USB device, in my case a printer. Both machines have access to this printer, so I know that the USB is working. I've tried reversing the cables, doesn't make a difference. If I boot the Vista machine using a dedicated mouse and keyboard, it comes up fine. I can then plug in the switched mouse and keyboard and they work fine until I switch to the XP machine and then switch back. After that the mouse and keyboard are not recognized again.
Any suggestions????
Your switch box will need auxiliary power.
Posted on Jan 21, 2009
3 Suggested Answers
firesnake09
  • 2923 Answers
SOURCE: Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Posted on Apr 06, 2009
SOURCE: using KVM-121 with 2 monitors
You should be able to -- the KVM switch would just switch inputs for the monitor, but since your two monitors would be plugged in directly to your computers, the switch wouldn't actually be affecting your monitor inputs.
Just make sure to plug your monitors directly to your computers and not use the switch.
Posted on May 23, 2009
I've got a 4 port switch with two computers hooked up - a desktop and a Lenovo Thinkpad R60 laptop - the desktop works perfect but when I switch to the laptop only the keyboard works - no video or mouse
The Thinkpad does not divert the video automatically to the external monitor via the KVM switch, you need to divert the video by pressing on the Fn key and the press the F7 key to toggle between the Thinkpad's LCD screen and the video port/external monitor. You may need to use a separate USB mouse connected to the Thinkpad.
Mar 20, 2011 | IOGear 4PORT DVI KVMP SWITCH WITH AUDIO...
I just bought d-link kvm-221... switching two pc's in a single monitor is working fine but the problem is my keyboard and mouse are not working (didn't detect by kvm-221).
D-Link KVM's have a shortcut for "resetting" keyboard+mouse.
Hold down Scroll Lock and press M
If that does not help, try unplugging mouse and keyboard for 3 seconds then plugging them in again.
Mar 11, 2011 | D-Link KVM-221 (DHKVM221) 2-port KVM...
Keyboard not working on one side of switch
the GCS632U has keyboard and mouse emulation that may not function correctly with docking stations. To ensure the KVM it self is working correctly I would suggest plugging the single USB from the KVM directly into the laptop and see if you have the same keyboard problem. This will at least tell you if the KVM is working properly or not.
May 16, 2010 | IOGear GCS632U 2-port KVM Switch
Hi . .. I want to use this KVM switch to connect
The GCS632U has keyboard and mouse emulation that may not work with all wireless combos. If your wireless combo is going to work the single USB connection would need to go into the keyboard port as that is the only port that will recognize the hot key switching commands. If the wireless combo still has problems then try using a USB wired keyboard to ensure the GCS632U is working correctly.
Mar 18, 2010 | IOGear GCS632U 2-port KVM Switch
I have a kvm switch vista lap and xp desktop stopped working
I've gone through alot of KVM switches. Something in the electronics just gives up. If your keyboard and mouse are the pci type (round connector) then don't switch their locations while the computers are on. Windows won't see the change and you may damage the system. If thy're USB type then switching is OK.
Apr 07, 2009 | Computers & Internet
All these codes are well and good, But how is the process done, what softwere do you use What do these KVM Switches do ? can any one help
the KVM switch is for using muliple computers on one keyboard, mouse and monitor.
  • Designed for Dual DVI monitor enabled PCs
  • DVI-I interface technology supports both digital and analog video signal transmission
  • Supports PS/2 keyboards and mouse including M/S IntelliMouse, Explorer and Logitech NetMouse
  • Switches instantly between two PCs
  • Keyboard and mouse are hot pluggable, eliminating the need to reboot your systems
  • Operating system independent
  • Supports high digital resolution of up to 1280 x 1024 and analog resolution of up to 1600 x 1200
  • Feb 27, 2009 | StarTech.com StarView SV211K 2-port KVM...
    Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
    Using KVM-121 with 2 monitors
    the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
    Sep 07, 2008 | D-Link DKVM-2K 2-port KVM Switch
    Mouse and keyboard not recognized on second computer
    Solution for the mouse. I have 8 KVM's. Most of my computers work with the KVMs. On 1 inland KVM the logitect and Microsoft optical mice do not work on one computer (but work with the other computers). They both are USB. I hook them up with a USB to PS2 adapter. If I use a ps2 ball mouse connected to the KVM the mouse works. All the Mice work if I directly connect them. Since I do not want a ball mouse I got a Frisby optical PS2 mouse. It works with all the computers on the KVM's.
    I do not have a solution for the Keyboard yet. 1 computer (ASUS MB) on my trendnet or belkin 4 postion KVM does not recognize the keyboard.
    Aug 25, 2008 | D-Link DKVM 2K (DKVM-2K) 2-port KVM Switch
    StarTech.com StarView SV431USB 4-port KVM Switch Logo
    493 people viewed this question
    Top StarTech.com Computers & Internet Experts
    loftys0504
    john1601
    Level 1 Expert
    Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
