Question about iRiver H10 MP3 Player
Iriver, H10 , system files missing
How do i restore the missing system files? it won't connect to the iriver plus program on my computer,it just freezes when i try. thank you
  • 8,596 Answers
IRiver H10 - Missing System Files
You must be connected to the internet for this to work: 1.Download the MTP Firm Updater Utility from iriver website - iriverinc.com/support (Audio Jukebox --> H10) 2. Unzip file, run .exe file, go thorugh wizard (if you are not in mass storage mode, it will give you instructions on the wizard on how to change this) 3. Select Recovery 4. Finish going through wizard 5. disconnect iRiver from computer, and wait for it to update - your player should be good.
If the problem happens again, then uninstall Windows Media Player 11 from your computer and rollback to Windows Media Player 10 (you will NOT lose any songs by doing so).
-Tha Mp3 Doctor
Posted on Sep 17, 2008
  • 3 Answers
SOURCE: Iriver H10 saying system Files missing
Try doing a format via windows explorer. Right click on the drive and then format as fat32. Then unplug and open iriver plus. Reconnect. See if that works. Good luck!
Posted on Aug 23, 2007
SOURCE: iRiver H10 - System files missing
please, my new iriver h10 is not open. it will say "System files missing"
Posted on Apr 14, 2009
SOURCE: iriver h10 when switch on it shows system file missing connect h
I'm not sure my solution can help you or not.
I've got this message too but after I formated H10 by Windows.
First backup all files by window explorer.
Open iriver plus and go to > Option > Portable Device Initialization.
This function will delete all data, Please sure that you already backup all of your data from H10.
After initialize process finished, it will ask you to disconnect and connect it agian.
------ Steps below, I can't explain it clearly. May be you will not have the same results as me. I hope it can rise you some ideas how it comes.
I followed that instruction but after I disconnected it again and turned on, expected that msg will disappear, IT's NOT! a bit freak out.
Ok claim down,
I tried to turn it off but I can't then I pushed its battery out and put it back and turned on, that msg showed up again.
Then I connected H10 to Iriver plus again and it upgrades firmware automatically.
At the end after I disconnected and turn on my H10 it works perfectly.
I'm not a native English so my language could make you confused, any questions you can contact me. :)
Posted on Jul 28, 2009
Testimonial: "hiiiiiiii thank u for helping me really i was screwed up but know its working and about ur english is perfect bye ."
SOURCE: SYSTEM FILES MISSING To restore the system files,
Ok claim down,
king_pathan786@yahoo.co.uk
Posted on Sep 28, 2009
chiefmecha
  • 600 Answers
SOURCE: have an iriver H10 - i turn it on and i get this
upgrade the firmware of your device follow this... How to upgrade firmware
1. Download the zipped file for your region.
2. Unzip the file and you will see *.exe file.
3. Connect your H10 to PC via provided USB cable and power on H10.
4. Once the device is ready, run the *.exe. It will automatically copy the firmware to your H10.
5. The progress bar copying firmware will be shown and your H10 device will give you 'Busy' message.
6. Once it's done, it will give you 'Upgrade Complete' message.
7. Please disconnect H10 with 'Safely Remove Hardware' option on your PC task bar.
8. Turn on the power of H10, go to 'Settings -> Extra ->Firmware Upgrade' and select 'Yes'.
9. Your H10 device will shut off automatically once the firmware upgrade is complete.
http://211.39.137.201//download.asp?filename=H10_5G6G_UMSUpdate(EU)_v203.zip&filepath=/file/Down/
http://211.39.137.201//download.asp?filename=H10_5G6G_UMSUpdate_v203.zip&filepath=/file/Down/
Posted on Jun 06, 2010
I reformatted my iriver player, and now it shows system error. what should i do?
Sir/ madam
good day.
me i ask regarding my iriver H10
the problem is system files missing
how to restore the system files connect H10 to iriver plus?
thank u?
Feb 19, 2010 | iRiver H10 MP3 Player
IRIVER WONT WORK AAAAHHH HELP!!!!!? my iriver wont work when i try to turn it on it comes up and says system files missing to restore the system files, connect to iriver plus wat dose that mean i have...
When system files are missing on the player, you will need to reinstall the FIRMWARE.
When looking online for the connection type for the H10 / H10JR, I can see 2 CONNECTION TYPES for the H10 / H10JR:
1. MTP, when using Windows Media Player 11 ( WMP11 ), for the H10.
2. iRiver Plus, when using iRiver PLUS, for the H10JR.
The connection type determines what software on the computer will be used for transferring media.
Each software on the computer needs corresponding firmware on the player to be installed.
When the player itself comes up with the information to connect to iRiver PLUS, this is the correct software for this device probably. Then the device is a H10JR.
When not having the program iRiver PLUS, go to the iRiver support site, for the download:
http://www.iriver.com/flash/index.asp?code=0302
In the left column click Plus3 and go for the download.
Run iriver plus 3 and then select [Tools > Portable Device > Firmware Upgrade] from the menu.
Need more help ? Just post a comment.
In case you have the other model player, the H10, let me know if you need assistance for its recovery.
Dec 15, 2009 | iRiver H10 MP3 Player
Iriver h 10 mp3
OK, one day i turned on mu iriver and it's say's "system file missing to restore the system files connect to H10 to iriver and i dont know how to connect it.The other proplem when playing the music it's like a scratch CD i dont know how to fix it.
Sep 25, 2008 | iRiver H10 MP3 Player
H10 6gb
iRiver H10 - Missing System Files
-Tha Mp3 Doctor
Aug 26, 2008 | iRiver H10 MP3 Player
IRiver H10 - System files missing
Aug 03, 2008 | iRiver H10 MP3 Player
Problem with sistem files of h10 6G. henry juarez
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 31, 2008 | iRiver H10 MP3 Player
H10
Male sure you have the Vista drivers/updated software from iRiver website
May 24, 2008 | iRiver H10 MP3 Player
IRiver H10-
What you need to do is set it on "Disk Mode" and check the firmware. Most problems like this occur due to missing or added files on to your firmware files. This corrupts the entire system, causing it to have strange malfunctions like yours.
don't panic!
bananaboy101
Dec 12, 2007 | iRiver H10 MP3 Player
Jun 29, 2007 | iRiver H10 MP3 Player
Reacquire firmware from iRiver website
Nov 13, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
296 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
