Question about Poulan Pro 22" Self Propelled High Wheel Mower
Changing oil how do i drain old oil from the mower.
  • Anonymous Feb 26, 2009
    How do I change the oil in the Poulan lawn mower?
UNDER MOWER WHERE THE BLADE IS THERE IS A PLUG WITH A SQUARE HOLE THAT A 3/8 RACHET WILL FIT IN TURN IT COUNTER CLOCK WISE. THAT WILL DRAIN THE OIL.
Posted on Sep 23, 2008
Where is the oil drain plug on this mower engine.
The oil drain plug is usually on the bottom of the engine. ,if not you may have to turn the mower on it's side and drain the oil out the fill tube.
Mar 08, 2015 | Garden
How to change oil in lawn mowers
remove the dipstick turn the mower upside down and dump the old oil tnto a drain pan. turn the mower uprite and fill with fresh oil. Have a nice day.
Mar 05, 2015 | Briggs & Stratton Garden
How to change the oil on a Briggs & Stratton 450
Sandy you can either drain the old oil from the spark plug socket which would be easier or the oil fill point. Remove the spark plug and tilt mower foward getting someone to hold a pot under it. When it's finished draining only put the same amount of oil back in (fresh) When you have done leave the mower somewhere level for a few hours and then start it. It may smoke for a few minutes.
Jul 21, 2013 | Garden
How to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Nov 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
How to change Oil
hello , well i use a pump,but since you don't have one the easiest way to change oil is to remove the dip stick and turn mower on side with the filler tube faceing down to drain oil,be sure and put a pan down to catch the old oil,and put fresh 20o/z of fresh 30 WT,oil in.hope this helps,any comments welcome,thank you.
Feb 20, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Keep having to change the spark-plug due to heavy black sooty build-up. Think the problem is old oil, therefore would like to know how to change the oil please.
there should be a drain plug in the bottom of engine warm lawn mower up take out drain plug drain oil out check your air filter replace it even if it looks clean replace it
Jul 24, 2011 | Briggs & Stratton Garden
Cannot get started after has started all summer changer spark plug and cleaned air filter Only problem is that also overfilled oil reservoir will that keep it from starting? If so how can i get some...
Hi pt--
If you are certain the oil is overfilled, then yes, this should be the problem. Single cylinder engines have little tolerance for excess oil in the crankcase. Since you're at it, you may as well change the oil in the mower while you have this all apart. In order to do this safely, be sure you have disconnected the spark plug wire from the top of the plug. You do not want the mower to start while you are under it. If you are unsure, ask someone who knows how to do this safely. You should also do this on a cool mower, as gasoline could leak from the tank or carburetor and pose a burning and fire risk. That said:
To change the oil on a single-cylinder lawnmower:
1) Gather materials.
--You'll need a pan or an old bucket to catch old oil, preferably one that has enough capacity for the old oil while also allowing the mower to be positioned with all four wheels on the ground.
--Some rags.
--A set of wrenches or a socket set.
--Two fresh quarts of new motor oil of the recommended viscosity for your particular lawnmower.
2) Disconnect the spark plug from the ignition wire. You'll see a cable running to the top of the spark plug. Grab it firmly at the boot that sits atop the plug and pull firmly. If it doesn't come off easily, be sure you are pulling at the right spot.
3) Tip the mower either backwards or on its side and look underneath the cutting deck. Be careful, as gasoline may spill from the engine's tank. You should see a small square-head or hex-head plug directly below some point of the engine. That is the engine's oil-drain plug. CAUTION: You may need to rotate the cutting blade to gain access to this plug. Be aware that the blade can cut you and that if the mower starts now it can cause serious injury to yourself.
4) Locate the correctly sized wrench or socket that mates to the drain plug.
5) Using a correctly sized wrench or socket, carefully and slowly loosen the drain plug until it turns freely by hand.
6) Position your drain pan beneath the engine's drain plug.
7) Unscrew the drain plug by hand until the oil drains free. Setting the mower down on level ground with all four wheels will ensure the most old oil drains from the engine at this point. Go ahead and open the engine's oil fil cap at this time, as this also allows the oil to drain freely.
8) When the oil has stopped draining from the engine--usually a slow drip is ok--you can replace the drain plug by hand. Be sure the plug turns freely by hand--do not crossthread the plug as you will create a costly repair for yourself.
9) Tighten the plug snug--NOT samson tight--with the correct wrench or socket and wipe any oil present at the plug or surrounding area clean with a rag.
10) Remove the pan from below the mower and rest your mower on all four wheels.
11) Slowly fill the mower's cranckase to full with fresh motor oil. Often, less than a single quart is necessary. Go slow and do not overfill.
12) Tilt the mower backwards again and check for oil leaks at the plug. You may need to snug up the oil drain plug one more time before the first after-oil-change start.
13) Lower the mower, reconnect the spark plug, and start the mower. Let it run for about a minute and listen to the mower for any "bad" sounds. If you hear anything out of the ordinary, shut off the mower immediately and recheck the mower for abnormalities.
14) Shut the mower off.
15) Check the oil level. You may have to top off the fluid level again, as running the engine tends to let the fluids settle out.
16) Disconnect the spark plug once more.
17) Tilt the mower and check the drain plug one more time for leaks. Snug it up as necessary.
18) Let the mower back down to the ground and reconnect the spark plug to the ignition wire.
You should be ready to mow again. Remember to be aware of any oil drips as push the mower around after a recent change--that may indicate the plug is leaking. There is a great picture of what a mower's drain plug looks like in the link below. Just scroll down to the part where you see the picture labeled 'oil drain plug.'
http://floridagardener.com/misc/tuneup.htm
--Hope this helps, Joe.
Oct 10, 2010 | Poulan "" Push Mower
My yard man mower is blowing black smoke when I crank it. Why would this be?? It was low on oil, but we filled it up and it still smokes. Do we need to change the oil? If so how? It has a honda engine, and...
Like the other guy says drain the oil out. Disconnect the spark plug wire (for safety). Place the mower onto a stable platform to work from. To remove the drain plug usually you need a 3/8 ratchet and I use a short extension so I don't skin my knuckles. Put the extension end into the drain plug and remove. Have a drain pan to catch the used oil. Clean the area around drain plug first. When oil is drained replace the drain plug and tighten. Add your new oil. ONLY ADD ABOUT 15 OUNCES. Use SAE 30 motor oil. Once you get the oil in set it on a flat surface and check for the proper level. Add if needed. Usually the push mowers only use about 16 ounces. I start with 15 because it is easier to add than remove the oil. Replace the spark plug wire, prime and start. It may smoke awhile to get the old oil burnt up.
Aug 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Change hydrostatic transmission oil
we have tractors and, yes any of those drain bolts will work (for best results do both) then after its drained, put the drain bolts back in and top up the level
Oct 27, 2008 | Husqvarna Garden
Poulan Pro 22" Self Propelled High Wheel Mower Logo
930 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
