Question about APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System
Inverter problem we have purchased 4 inverters for hi-style apparels and diva textile showroom. recently it is not working we dont know why it is not working
  • 615 Answers
Check the fuses and the connection you may had a surge or reset your power supply
Posted on Sep 08, 2009
    Scholar:
  • 64 Answers
If you got the store bought APC 350 UPS, you most likely overloaded them, and killed them beyound repair.
People should never buy a 350VA. They are way to small for power supplies most of us now have. you need to start out to 1000VA plus you need to do the math to figure out how big of a UPS you actually need in the show room.
What am I talking about? What is the significant, or the math of what I am saying here. 115V x 1 amps = 115VA x .778 power factor = 89.47 watts Start up 50 watts = 39.47 watts
115V x 2 amps = 230VA x .778 power factor = 178.94 watts Start up 50 watts = 128.94 watts
115V x 3 amps = 345VA x .778 power factor = 268.41 watts Start up 50 watts = 218.41 watts
115V x 4 amps = 460VA x .778 power factor = 357.88 watts Start up 50 watts = 307.88 watts
115V x 5 amps = 575VA x .778 power factor = 447.35 watts Start up 50 watts = 397.35 watts
115V x 6 amps = 690VA x .778 power factor = 536.82 watts Start up 50 watts = 486.82 watts
115V x 7 amps = 805VA x .778 power factor = 626.29 watts Start up 50 watts = 576.29 watts
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts
115V x 9 amps = 1035VA x .778 power factor = 805.23 watts Start up 50 watts = 755.23 watts
115V x 10 amps = 1150VA x .778 power factor = 894.70 watts Start up 50 watts = 844.70 watts
115V x 11 amps = 1265VA x .778 power factor = 984.17 watts Start up 50 watts = 934.17 watts
115V x 12 amps = 1380VA x .778 power factor = 1073.63 watts Start up 50 watts = 1023.63 watts
115V x 13 amps = 1495VA x .778 power factor = 1163.11 watts Start up 50 watts = 1113.11 watts
115V x 14 amps = 1610VA x .778 power factor = 1252.58 watts Start up 50 watts = 1202.58 watts
115V x 15 amps = 1725VA x .778 power factor = 1342.05 watts Start up 50 watts = 1292.05 watts
115V x 16 amps = 1840VA x .778 power factor = 1431.52 watts Start up 50 watts = 1387.52 watts
115V x 17 amps = 1955VA x .778 power factor = 1520.99 watts Start up 50 watts = 1470.99 watts
115V x 18 amps = 2070VA x .778 power factor = 1610.46 watts Start up 50 watts = 1560.46 watts
115V x 19 amps = 2185VA x .778 power factor = 1699.93 watts Start up 50 watts = 1649.93 watts
115V x 20 amps = 2300VA x .778 power factor = 1789.40 watts Start up 50 watts = 1739.40 watts
2 Suggested Answers
  • 25 Answers
SOURCE: can extra battery be added to a ups that has a small battery
yes you can but you need a coupler for the extra battery back, you can find one at an electronic store.
Posted on Jul 11, 2009
How to change blown fuses
Ben, Power Inverters of different make and style use different fuses, I will post links for you to check out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Replacing Fuses Power Inverter
Homemade Circuit Projects How an Inverter Functions How to Repair...
Battery Sales Inverter Frequently Asked Questions FAQ
POWER JACK GRID TIE INVERTER REPAIR THE MOSFET MISHAP
Feb 26, 2016 | Electronics - Others
Hi, We have KEB F5 inverter on our machine model
If you are connected to the inverter with COMBIVIS, go to parameter FR.01 and enter a value of -4. This will set all parameters back to factory default.
You may be having an issue with the inverters software verison. As long as the inverters are the same part number, you should be able to download the parameters without any issue. There may be some unknown parameters but you should be able to hit ignore and keep on downloading.
Oct 26, 2013 | Inverter KEB COMBIVERT F5
I recently purchased a schumacher 410w inverter, while it came on right away and powered my electrical device the cooling fan never came on. Is the fan supposed to run all the time, once its connected.
I recently purchased a Schumaker 410/820 watt inverter. I immediately hooked it up to a brand new deep cell batery I had purchased just prior to receiving this inverter.
I plugged in several devices to make sure the inverter worked and to get some idea of what devices I can expect this unit to handle.
I noticed that the fan only ran when I plugged in a device that drew a certain amount of power from the unit. I also plugged in a CPAP unit to make sure the inverter would operate the unit properly, and noticed that the CPAP only drew 38 to 40 watts of power and the cooling fan on the converter never came on. When I plugged in an oscillating fan it drew around 128 watts from the converter and the cooling fan immediately came on when I turned the fan on. Based on that, I would assume that the cooling fan in the converter only runs when there is enough power being drawn through the inverter to cause the inverter to heat up enough to cause possible damage to or failure of the inverter. I haven't taken the time to find out the power draw at which the cooling fan will run. Hope this helps.
Jul 10, 2011 | Schumacher 410 Watt Power Inverter...
This is a Wagan 2003-6 400Watt with USB DC to AC Inverter. Worked great for almost a year. Recently fan was varying in speed under load. Then finally blew my vehicle cigarette lighter receptacle fuse. ...
A few thoughts on this. With the transistors, if these are a darlington style of transistor, it might show a short on a good transistor. The USB "transistor" is a voltage regulator, 12v to 5volts dc. With the inverter input, some inverters use a diode in the input to protect against connecting the inverter by reversed leads. This diode might be shorted and be causing your problem. If it comes to changing the transistors, it might be cheaper in the long run to buy a new inverter. The transistors might be problematic and might not be the only thing problematic. Experience here talking!
Feb 05, 2011 | Wagan 20036 400 Watt Power Inverter Corp
Which type of the frequancy refferance source is given to toshiba make inverter VFA3N-8075PY-A70 ? which is used in teijin seiki winder in textile machinery.
Replace VFA3N-8075PY-A70 with CIMR-AT2A0040 & PROTOCOL CONVERTER!
Yaskawa inverter can replace the inverter with communication converter.
We have the solution on it, also TORAY T3 spindle inverter.
Fell free to contact us.
James park hyundai-sys@hanmail.net
Jan 17, 2011 | Toshiba Satellite U400/U405 Power Inverter...
Have recently purchased a Sunforce 11264 4500W true sine inverter, shipment pending. trying to find a view of the back side of it to determine the 12V service connections needed, PDF of manual indicates a...
Hi , i'm sorry but i dont really understand your question , assuming the current draw is around 45 amps then 2 /0 GA is fine , just keep your leads from your panel nice and short , the connection kits are sold by sunforce and there plenty of suitable connectors on the market
example link below
http://www.globalepower.com/Datasheets/BatteryConnectors/BatteryGlobal.pdf
Aug 17, 2010 | Sunforce 11264 4500 W Pure Sine Wave...
Is my inverter working correctly?
An inverter should work immediately.
Jun 10, 2010 | Electronics - Others
Keb inverter and lenze inverter
I would have to say that you will not be able to swap the KEB inverters with the Lenze inverters or the Lenze inverters with the KEB inverters.
The PLC ProfiBus system would most likely need to be re-programmed for the change.
Mar 11, 2010 | Inverter KEB COMBIVERT F5
I have a cobra cpi2575 inverter and the led screen keeps saying OPP even after i unplug everithing exept the power cables
We hope it is still new and can be returned, do it as fast as possible.
You will find it hard and very costly to repair it.
Starting ad 75.00 an hour with the bill being around 175. before your running again.
If at all possible Return it and consider it a lessons learned and purchase an nicer Pure sine wave inverter in the 1500 watt size area. they tend to be much better and are much more capable of running full time under a load.
Sad new I'm sure for you SORRY. I'm a Seven inverter owner with only one good inverter to show for all the trouble.
r/ David
Jan 02, 2010 | Cobra 2500w Power Inverter
Where i can buy toshiba satellite p10-304 display screen inverter
You will be able to purchase an inverter board here>>>>>>>
http://www.impactcomputers.com/k000009570.html
Take a look at the back of the inverter for a copper coil, if youre-solder the solder points around the coil you may find it works againas components that suffer from extreme heat the solder joints drycausing bad connections, re-floating the solder solves the problem in90% of cases.
If you don't know how to remove the inverter from the bottom of the screen then please post back.
Regards.
Sep 29, 2009 | Toshiba Computers & Internet
APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System Logo
433 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
