Question about Lexmark X1270 All-In-One InkJet Printer
It says "failure to communicate with the printer" and doesn't print
Subject
Says printer is failing to communicate with computer. How is this fixed
Posted on Sep 16, 2008
Why doesn't my printer communicate with m,y computer?
Try uninstalling and reinstalling or doing a repair. Make sure you have your install cd handy. You can uninstall or repair by going to control panel > hardware and sound > devices and printers. Then right click on the printer and either troubleshoot or remove the printer all together.
Apr 04, 2013 | Lexmark Z2300 Color Inkjet Printer
0xc19a0035
The ink system failure is a pain to troubleshoot. It could mean that the ink cartridges are not communicating with the print head, the print head is bad or the entire printer needs service.
Try resetting the printer to clear the error from memory:
First with the printer on, unplug the USB cable (if using one) from the printer (and the computer).. Then remove all of the ink cartridges from the printer (lift the scanner unit as if to change the ink). Wait for the printer to indicate "Insert ink cartridge). Then unplug the power cord from the back of the printer. (Note: do not turn off the printer just disconnect the power cord.) I also disconnect the power cord from the outlet and the power adapter (this resets the adapter). Wait 60 seconds or longer. Then reconnect the power cord to the printer, the adapter and then the outlet. Turn on the printer if it doesn't turn on on its own. Reinsert the ink cartridges and close the printer. Print a calibration page if prompted to do so. Finally reconnect the USB cable. Try printing again.
If the message repeats, the unit needs service. This printer doesn't allow the user to service the print head so the cost for servicing is variable. If the printer is under warranty, contact HP for service. Otherwise decide if it is worth the cost of service (expect a minimum charge of $50 just to determine the problem.)
I hope this helps.
May 16, 2012 | HP Photosmart C8180 All-in-one -...
Not communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Dec 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
My printer will not print. I can scan images but nothing happens when I go to print a document. There is no box that comes up that states there is a problem.
Your firewall could be blocking the print communication. The article below will guide you on how to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
- Communication Failure When Trying to Scan, Print, or Perform a Smart Solution Function; Firewall Possibly Blocking a Process and Preventing Communication
Hope this helps.
Aug 24, 2011 | Lexmark X4650 InkJet Printer
I cannot get my Cannon D 880 to print from my computer. It will copy images, but get failure when I try to print. I have a USB connection, drivers are present it is plugged in and I cannot print. It says...
Communication Control
Communications with the PC are controlled using a bi-directional parallel interface (IEEE
std 1284-1994) or USB (Ver. 1.1). The communication protocols used for bi-directional
communications include: Nibble, ECP, Rapid Port.
Jul 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
TOP FIRST LIGHT IS CONTINUOUSLY BLINKING
Same problem starting this week, is there a reset? If so , how?
Jul 22, 2008 | HP LaserJet P2015dn Printer
NO COMMUNICATION
hi i have zebra z4m plus printer when i give them command for printing it's not printing and i need a solution can you please help me thankyou
Apr 10, 2008 | Zebra Z4Mplus Label Printer
Unable to communicate to a 1320n laserjet printer
unistall the driver completly and install again so after that click shared printer and them try it
Sep 25, 2007 | HP LaserJet 1320n Printer
Lexmark X1270 All-In-One InkJet Printer Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
