Question about GE Washing Machines
GE #VXBR1070W0WW Washer: Problem, washer comes on when dial is activated, it fills with water, lets out water. But,it do not wash, rinse, or spin. What should I do?
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    VXBR1070W0WW does not come up as a valid model number. Look on the frame of the machine under the lid, on the top edge of the backsplash, or on the very bottom front left side panel for the model / serial number sticker. Also, aprox age of washer?
  • 1,543 Answers
Your lack of response to my clarification request leads me to beleive you have resoved your problem. If not, please add additional info.
Posted on Oct 05, 2008
Will fill but not wash or spin
Does the motor run?  Does the water get pumped out at the end of wash cycle or during the rinse cycle or when you turn the dial by hand to the end of a cycle?  If the water gets pumped out then the motor is OK but the clutch is not working.  If the motor is not running then that is the problem.  If the water fills and then nothing happens (the dial does not turn by itself) the timer is bad.  If the timer is bad but you turn it by hand the other actions (wash, rinse, etc. should work indicating no problems with motor and clutch).
May 30, 2009 | GE WBSR3140DW Top Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Kenmore top load washer will not fill on rinse cycle
Hi, It does sound like the contacts in the water level switch are sticking. This switch is activated by presure not vaccum. You can try and bow into the hose leading to the level switch and see if it has any restriction but, it is more likely the level switch is going bad.
Do you have any problem on the initial starting of you wash cycle?
Let me know if this helps at all or I can answer any more questions.
Thanks
Vic
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
My brandnew ge top-loading washer does not enter into the rinse and spin cycle. it washes drains and spins then stops there.
Check the cold water inlet. Valve on? Hose not kinked? Inlet screen where hose connects to washer not obstructed with debris? If all these check out OK with still no rinse water fill, call for warranty service. (hope you didn't buy from Sears, as product from there does not come with factory warranty !)
Feb 26, 2009 | Kenmore 24032\24036 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
22 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
