Question about Dishwashers
My LG dishwasher is about 1 1/2 years old. My problem is that the detergent is no longer being dispenced properly. Much of it remains in the dispencer after use. What can I do about this?
    Guru:
  • 1,894 Answers
Open the dispenser while the machine is in operation and pour some extra water.
this will make the detergent to flow more inside the machine fully
Posted on Sep 16, 2008
  • dewan nafees ahmed Sep 16, 2008
    If there is still detergent in the dispenser when the load is
    done, make sure the cycle has actually finished, and make sure that
    nothing has blocked the dispenser cup from opening fully. Otherwise,
    you may have old detergent. Discard the old detergent and use fresh
    detergent.
I have a 13 year old Maytag that works great. But recently the flipper door that dispences the dry detergent doesn't open during the wash cycle. I've tried cleaning it thoroughly, but that hasn't made a...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 17, 2010 | Maytag 24 in. MDB6600A Jetclean II...
The dishwater detergent dispencer doesn't open when it should during it's timing cycle.
HI, this is the result of a damaged Actuator assembly. you will need to replace this assembly. it is a spring loaded assembly that dispenses the detergent.
It is damaged. Replace your
Actuator assembly for detergent dispenser
Jun 01, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
ZANUSSI 695 Integrated Dishwasher
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
Jan 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Nov 24, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hotpoint Dishwasher
The dispencer soilnord is broke , change the dispencer.
Nov 09, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Soap left in the dish
With the LG LDS5811 dishwasher and other water/energy saving dishwashers, they are VERY ineffective with untra cheap powder detergent. Switching to Electrosol or Cascade has solved the problem -- and don't use too much.
If you add a whole house water softener, you will be AMAZED how much better your dishwasher and clothes washer work -- especially if your cut down on the amount of detergent your use.
Oh, never use gel or tablets in your diswasher. Ever.
if the problem with the detergent dispenser not opening is a seperate problem. Recommend you submit a seperate problem/question.
Good Luck!
Aug 26, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwasher soap remains in the soap dispenser following the complete cycle. I have had the washer for a year and a half. The first year, no soap remained in the dispenser. Now about 1/8th of the soap...
Try cleaning the soap dispenser with white vinegar so that it is free of all detergent, then try using about 1/4 less detergent than you have been to see if you still have any remaining in the dispenser. Also, make sure your drain filter is free of all sediment so that the system can pump the water out freely. Lastly, if you are still getting some soap remains, then try using a sanitary setting that uses the hottest water and see if the excess soap is properly dispensed. Your water temp may not be getting hot enough so this test should help identofy the solution. Hope this helps !
Aug 20, 2008 | Whirlpool Dishwashers
Dishwasher
Paula,
If this product is under 1 years old, call LG Customer Service to have a qualified technician take care of this problem.  Their number is 1 800 243 0000.
Jul 14, 2008 | LG LDF6810 Built-in Dishwasher
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
May 26, 2006 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
