Creative Modem Blaster with Bluetooth remote dial-up VISTA problem
We use the Creative Modem Blaster with Blue tooth Wireless Tech CB5722 for dial-up as in this area we can NOT get high speed internet what so ever! This equipemnt works beautifully on the Microsoft OP systems EXCEPT VISTA!!! We currently purchased a new portable MAC as well as a new portable PC both equiped with wifi AND Bluetooth. the PC has VISTA the MAC op 10+. Obviously we woudl like to use teh bluetooth wireless modem blaster to logonto the interent with these new portable machines, however the VISTA op does not seem to work with the blaster nor the MAC op.
The easiest thing would be for us to access the Creative Blue tooth modem blaster form teh remote machines.. does anyone have the drivers or a solution for this?
OTHERWISE... more complicated and hindering...
We could dedicate one of our older XP PCs as a dial-up server.. equiped as well with a wifi AND bluetooth.
Once we join the network that has this machine on it..
How can we force the VISTA and/or MAC machine to run the XP application AND/OR remotely ask the slave dial-up machine to dial-up the internet?
We also have a D-Link wifi router (currently installed on the MAC, how can the PC also join and see this network?
debbily
  • 101 Answers
SOURCE: 3 PC's networked to BEFSX41 very slow accessing internet
sounds like your internet access is the slow down, not the router. You don't say if you have DSL or CABLE or what.  I'd check there. Make sure you are getting a strong signal.  Hook up one system directly, without the router and check the speed.
Posted on Oct 14, 2007
joe3959
  • 24 Answers
SOURCE: Creative Modem blaster..
http://www.modem-drivers.com/companies/258.htm
See if this link can help u find your right driver!
Posted on Jan 01, 2009
frcs68
  • 1605 Answers
SOURCE: access home network remotely via zyxel modem
you will not be able to access from one network to another even if you are on the same workgroup. However, you can setup VPN on both side. the other is to use commercial remote software. i.e.: vnc, mypc, teamviewer, etc.... they don't need anything else, but do require setup on both machine. This is much easier, don't need any permission from the network administrator, or company permission.
Posted on Jan 09, 2009
len52155
  • 20 Answers
SOURCE: Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
Posted on May 20, 2009
crapiemael
  • 241 Answers
SOURCE: After replacing Cable Modem, D-Link DI-524 Wireless will not work
Did you call Comcast and give them the new MAC address of the Motorola SB5101 SURFboard cable modem? I'm surpised it works at all without doing this first. This is the hardware address of your modem so the world can see you, no one in the world has the same MAC address, they are all different. It's on a sticker on the modem.
Posted on May 28, 2009
Using a broadxent DI3635 modem. I can dial but will not connecton my desktop with Win XP, however on notebook using Vista, works fine.
probably winXP needs aditional software for the proper working of this hardware ,
WIn vista may have the software within it so that it woks fine
you could find the software or assistance in the in the website of the modem provider dont forget to comment and vote thanx
Mar 25, 2011 | Broadxent Creative Blaster Di3635 Modem
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
My bluetooth usb wont work on my laptop .I usein vista and it tells me that it is a toshiba stack
Initially check whether the drivers for the blue tooth is installed or not .
This can be seen from the device manager if there is no drivers installed for it install the drives needed for it by using the cd provided with the blue tooth.
.After installing the drivers when u plug the dongle you have got led blinking inside the device if the led is available .
if the above steps give you positive result sure your bluetooth will work. if not there may be some problem in the device
Mar 10, 2010 | Macally BT-SYNC Bluetooth (BTSYNC)...
Is Acer Aspire 4720z equipped with a built in blue tooth device
The quickest and easiest way i have found is to press the Fn button + the one that turns on your wireless networking if you have one.
But i looked up your system and it says it comes with blue tooth.
"Communications Intel® Wireless WiFi Link 4965AGN network connection supporting 802.11a/b/g/Draft N wireless LAN, Acer® SignalUp technology for enhanced antenna efficiency
or
Intel® PRO/Wireless 3945ABG network connection supporting 802.11a/b/g wireless LAN, WI-FI CERTIFIED™, Acer® SignalUp technology for enhanced antenna efficiency
Bluetooth® 2.0 + EDR (enhanced data rate) wireless PAN (select models only)
Gigabit LAN, Wake-on-LAN ready
V.92 56Kbps* data/fax modem, PTT (postal, telegraph, telephone) certified in select countries, Wake-on-Ring ready
Acer® Video Conference with integrated Acer® Crystal Eye webcam supporting Acer® PrimaLite technology, which consists of a premium sensor, firmware and lenses to provide superior video performance under low-light conditions (select models only) "
I found this here
Feb 27, 2009 | Acer Aspire 4720 Notebook
Loss of internet, blue tooth light wont turn back on
Here are some things to try. I would remove the bluetooth adapter. Is it built in? If so, you will not be able to do this. If it is an adapter take it out and try putting it back in. Did you install new software? Do you have anti-virus? I would recommend that you do a system restore to the point of when it happened. The system restore will restore the settings previous to the incident. Now the next thing is to do a right click of the system and go into properties. Depending if you have Vista or XP the Device Manager will be in different spots. Look in the Device Manager and uninstall the BlueTooth. Reinstall the device. If the BlueTooth is built in then you will probably have to contact tech support at Gateway.
Let me know if you have any other question.
Dec 31, 2008 | Gateway Computers & Internet
SGH-E250 internet access via data cable or blue tooth to PC
You have to buy a data cable or use bluetooth.Create a dialer which dials *99# using your samsung modem over bluetooth
Dec 11, 2008 | O2 Samsung SGH-E250 Cellular Phone
Creative modem D15663
pls I need a driver for creative modem blaster D15663,pls help me
Sep 23, 2006 | Creative Labs Blaster V.92 Modem
Computers & Internet Logo
David Payne
David Payne
