Question about Crosley 4-in-1 Entertainer CD Shelf System
Turntable belt is broken
Where can I buy a new belt for the turntable?
  • 104 Answers
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
the site in the video will also help you find the right belt.
Posted on Feb 12, 2009
The turntable isn't turning on one of our units and the cassette player isn't working on another. Where can they be fixed? Just bought needles for both.
My turntable quit and I found out it had a broken drive belt. Mine was easy to get into but can't buy a new one They don't make mine any more. I suspect your player could have a broken belt as well. I put mine in the garbage. No parts and going to cost more than new to repair.
Oct 23, 2016 | Audio Players & Recorders
Ineed a turntable belt for tpc-hd 12
Fixya is not a buying service. Try an internet search for turntable belts.
Oct 17, 2016 | Audio Players & Recorders
5 years old and not sprinning is for every turntable bad, i'll never buy a technics which has been in a box for 12 years. I think since the lubrication of your cheap motor works fine, but if it never spins a part has run dry. Your belt can be broken, but then that you'll notice . It just can't be a lot , Did you check the output of your powersupply.....
You can check if the cable that runs to your switch is connected and otherwise you buy another motor, though i wouldn't spend a lot on it, since you buy them new for zero money with a better arm and motor.
Feb 16, 2015 | Project DEBUT III Turntable
My Pioneer PL-112D turntable has a broken drivebelt, is it possible to buy a new one, and is there a diagram showing the belt "routing". Thanks.
I don't believe this belt is being provided by the Pioneer. So I did find another option at a reasonable price on E-bay.
Jan 17, 2011 | Pioneer Audio Players & Recorders
Turntable will not turn.
This is a belt driven turntable, check the belt if it is loose replace it with a brand new one, you can buy one at
Aug 19, 2010 | Pioneer PL-990 Turntable
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
I need to put new turntable belt on a Technics SL-B200
The belt goes underneath the turntable platter. First you attach to the lip on the bottom of the turntable platter, then you put the platter on the turntable. You'll see some holes on the platter, after you put it on, just rotate the platter, until you see the motor shaft, then pinch the belt around the motor shaft.
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 01, 2009 | Technics SL-1210 Turntable
Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
for about $16.
Paul H.
May 03, 2008 | Technics SL-1210 Turntable
Turntable rotating slowly or not at all
First and foremost, are you sure you installed the correct replacement belt, and installed it correctly? Just ruling out the obvious. Now, if you installed the belt correctly, then the only other thing that could cause this is a bad motor. Not an expensive part, but with labor, it might be cheaper to just buy a new one. Figure the part itself is about You will more than likely be able to remove the cartridge/stylus and use it on your new turntable, just make sure the tonearm is the same style as your existing turntable - P-MOUNT Tonearm. If you buy another belt drive, you might even be able to keep the belt you purchased as a back up - might fit! Here is some part info on your turntable: - Belt - Part #SJY90080-3 - $5.99 - Motor - MOTOR, 4 VDC, .2 WATTS - Part #SDMB5E - $19.99 Labor - 30min This is just to give you an idea of what it would cost to replace the motor. I put the belt part # on there, just so you could verify that you bought the correct part. Hope this helps some. - Justin
Aug 02, 2007 | Technics SL-BD22 Turntable
Crosley 4-in-1 Entertainer CD Shelf System Logo
316 people viewed this question
Top Crosley Audio Players & Recorders Experts
da surgen
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
