Question about GN Netcom Radio Communications
GN Netcom Ellipse 24
I moved from an office to a home office, and am trying to get my headset to work with my home office 2-line phone. I have it hooked up, but when I plug in the power to the headset, the headset makes an intermittent "ringing" noise. Sometimes it is constant, and other times it just comes and goes. It doesn't seem to be related to any other activity in the house (microwave, other phones, incoming calls, etc.)
SOURCE: GN Netcom GN 9120 - can't hear
Hi There, I had the same problem with a headset one of our call centre reps were using. It's usually due to some one fiddling with the button. I got it working by removing the battery from the headset then resinked the headset to the base unit. Hope it works for you
Posted on May 19, 2008
SOURCE: Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
Posted on Jul 16, 2008
SOURCE: GN Netcom 9020 Wireless Headset
Gn/Jabra will replace it for about $50. Just call their help line.
Posted on Nov 06, 2008
  • 32 Answers
SOURCE: GN Netcom wireless headset volume adjustment
Transmit volume adjustment
Adjust the volume of transmitted sound according to personal preference.
To adjust the volume:
1. Make a telephone call and ask the person you are calling to assist
you.
2. Press the +/– buttons on the headset simultaneously for 2 seconds.
A beep will indicate when 2 seconds has passed.
3. Adjust the volume level by pressing the + or – button.
4. When the person you are speaking with fi nds the volume of your
voice appropriate, press the +/– buttons simultaneously for 2
seconds. This setting is now stored in the headset.
A Copy of the manual is avaliable at:
http://www.onedirect.es/files/GN%20Netcom-ES/GN%20Netcom%209120%20manual.pdf
You must have Adobe Reader to view it and the instructions are on page PDF page 3 or manual page 6. Adobe Reader is avaliable for download at:
http://www.adobe.com/products/acrobat/readstep2.html
Posted on Nov 12, 2008
SOURCE: GN Netcom GN 6210 - headset, no worky
Not sure what you mean by won't turn on.
If you mean no dial tone when you take it out of the cradle, I have run into this. The solution is to unplug the power cord and then plug it back in which resets the unit.
Posted on Dec 28, 2008
The handset will lift when I press the mfb but I get no volume or mic from the headset. It does not seem to be communicating with the phone. Tried unplugging the power, but that didn't solve it. We...
Your solution will depend on what type of phone and headset you have. I have a Polycom 501 IP phone with a headset jack and a GN Netcom 9125. I'm not using the lifter right now, but I seem to recall that an easy way to make it work was to plug the curly cord of the phone's handset into the bottom of the base unit, so that the cord went from the base of the headset to the headset jack on the base of the phone.
Jul 11, 2011 | GN Netcom GN 1000 RHL Wireless Headset
When I plug the phone line (Comcast is the provider) into my GN Netcom GN7100 Base it "shorts out" (according to the Comcast Tech) the voice modem and so I can't get a dial tone. This makes it impossible...
1. Be sure the jack on the base unit is clean and that the pins inside are straight. 2. If try line another cord - the cord is often the problem due to twisting or crimping. You can test the cord on another phone if you don't have a spare. 3. Make sure the headset is in the off or "on-hook" position. 4. To see if the unit itself is defective try it at a friend's house. Do other phones work OK on that line?
Aug 11, 2010 | GN Netcom GN 7100 Corded Phone (GN7100)
GN Netcom heatset buzz
I had this problem a few months ago, make sure the small wheel on the side is set on A. (if you look closly at the wheel there are very small and hard to see letters on there.) this should get rid of the buzzing.
Jan 28, 2009 | GN Netcom (9120-48) Wireless Headset
GN 9350 Wireless Headset doesn't ring on the headset when phone rings
It only picks up certain digital rings. I changed the ringer on my phone and had the same problem. To fix it, I had to plug in the little microphone that plugs into the handset lifter and place the mic over the ringer speaker. Now it works fine.
Jul 11, 2008 | GN Netcom GN 9350 Wireless Headset
Pairing GN Netcom GN 6210 with my iphone
Press the talk button on the 6210 Device and hold it until you here (2) faint beeps. Walla! (poor design and documentation?)
Mar 08, 2008 | GN Netcom GN-6210 Consumer Headset
DTU 16D-2 Corded Phone
headset key has to be programmed on a key for it to work properly
Jan 23, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Sep 01, 2007 | GN Netcom (9120-48) Wireless Headset
High pitched squeel
change the dial settings on the side (there's letters from A to G)
Feb 16, 2007 | GN Netcom GN 9120 Professional Headset
Open Questions:
Radio Communications Logo
133 people viewed this question
Top GN Netcom Radio Communications Experts
Tom Chichester
MrFixitSTTL
techmncpa
Level 1 Expert
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
