Question about Saitek CYBORG EVO FORCE Joystick
Force Feedback trying to pull right all the time
I was wondering if you could help me -  My Evo Force pulls right and backwards all the time. it never centres itself.
Have you ever heard of this problem?
thanks
Nick
  • Anonymous Dec 10, 2008
    Cyborg Evo Force goes right! Don't know, what to do!
  • dodac Mar 13, 2009
    Running flightsim x when starting to taxi down the runway cyborg evo force pulls to the right.
    Can get it to go sometimes by playing with settings but is really annoying as i have learnt i,am not the only one.
    Seems like a coomon problem had a logitec without any problems.
  • 114 Answers
Hmm, never heard it before. you maybe have a driver issue, try re installing drivers then let me know.
Posted on Nov 15, 2008
Froze on video and now black screen
Try pressing the back and home keys a few times. Sometimes a program hangs and the input prompts android to display the force close option to end the application.
If that doesn't work, try holding in the power button for about 10 seconds and see if the power down options appear (this might cause the force close to appear too, if so go for that method, if not shut down and power back up).
If none of that helps, you may need to pull your battery and boot it back up.
Please leave feedback if you found this helpful. Thanks.
Mar 31, 2011 | Motorola Mobility MILESTONE XT720 Cell...
Genius MaxFighter F-16U ... When i get into ANY game with Joystic support .. Jet fighters and etc ... I Pull the joystic and it wont pitch ...also it cant go right when i pull the stick to the right . ...
Hi, When you set your joystick up using the in game controlls menu try this. Try setting the controls from the bottom up I will try to explain. Lets say in the controls menu from the top it starts like this> 1)Pitch forward 2)Pitch backward 3)Roll right 4)Roll left. Start with pitch backward and pull the joystick back, It should auto input the pitch forward control. Next you would move on to roll left, It should auto input the roll right control. Get what im saying, You should only have to input one direction the other should auto input. Had the same problem with my LG extreme pro for BF2. Hope this helps good luck!
Jan 04, 2011 | Genius MaxFighter F-16U. USB PC Joystick...
Cyborg evo force joystick seem to chatter with or without force effects on or off in fsx and il2-46, i have remove all drivers and re-installed several time with no improvement,even disarmerd stick in...
You might clean out the registry of any left over values. Try it on another machine if it still does it, its something mechanical inside maybe stuck. I suppose its out of warranty? You cant fly with those stickers anyways if that's what you do. Scourer the junk shops for an old MS Sidewinder, they are still the best stickes ever made.
Jun 18, 2017 | Saitek CYBORG EVO FORCE Joystick
Removal of Base from Monitor
it's little trickey....u need to try and use little force and twist it to left or right and just pull it out....
dont use any tools it can damage it...
push it little forward / backward ...left /right...twist pull
Dec 17, 2009 | HP Compaq S9500 (Silver, Carbon) (Carbon,...
Dvd/cd drive problems
sometimes the top has to slide either forward or backward BEFORE you pull up on it----------usually slides towards you if you are in front of the machine. Sometimes also you will see some plastic clips on each side that you have to pry outward very gently AT THE SAME TIME and then pull up on the top. Look at it very thouroughly from all angles and you will discover what has to be done. Sometimes there are a couple or more of screws that have to be unscrewed, but in most cases, it's just a plastic clip and/or the top slides before pulling up on it. Hope this helps. Keever
Mar 10, 2008 | Computers & Internet
Finding Force feedback joystick PC games
ghost recon any tom clancy games band of brothers medal of hounor
Feb 23, 2008 | Video Game Consoles & Games
Vista drivers
Me too. Can anyone help please? I already mailed Logitech for this.
Nov 10, 2007 | Logitech Force 3D Pro (963352) Joystick
Paper is pulled into printer unevenly and then jams
Hi Jocase, there is most likely a foreign object in the paper path of your machine. Often tipping it on it's back will dislodge the offender, but not always. Take an A4 sheet of thick card (the back card off an A4 refill pad is good for this) and push it backward through the paper path. Start where the paper normaly comes out and feed the card backward throught hte exit rollers, and on toward the main feed rollers. Don't go too far to the right side (wear the head "parks") as the paper sensor could get broken off. Persuade the card through the rollers and gently tease it in in out. Tip the machine on its back again so anything dislodged is encourage to come out. Work the card in and out GENTLY taking care not to exert too much force. If nothing falls out, you may have to dismatle the machine to get to the ASF to manually remove the oblect. If you intend to dismantle the machine, get a manual from http://TheServiceManualShop.com to make sure you do it right without breaking anything.
Nov 14, 2006 | Epson Stylus CX6400 All-In-One InkJet...
Saitek CYBORG EVO FORCE Joystick Logo
243 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
