Question about Microsoft Computers & Internet
PC tower problem
PC beeps once every 10 seconds, have to unplug it to shut it off. Windows does not load up. Monitor is blank. What is wrong with this computer??Thanks, Carol
  • cbarb Sep 19, 2008
    I reseated the RAM and now it works, that you so much. At least that is what I think did it. No more beeping and the windows loads up great.
    Thanks again.
Looks like a main board problem. Check RAM / Memory is seated correctly
Posted on Sep 16, 2008
Using ASUS P5GZ-MX motherboard, running Win Vista. It's supposed to beep once on power up but has stopped. Previous to this, the PC started trying to boot over and over by giving a beep every 10...
* beeping is all about processor,try to clean the surface and check the heatsink if still have a paste on it or change the processor for trial and check if the problem is still they same.
* also check the powers supply,voltage might get open. That's why power failure occur.
good luck..
Jun 14, 2011 | ASUS P5GZ-MX Motherboard
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
P/c goes on, but desktop stays blank, icons will not appear
Hi this is due to static
do the following
1) Unplug all the cables from the back of the computer tower and monitor including the power cable.
2)press and hold the power button for the tower for 30 seconds do the same for monitor this will release all the static.
3) put back the cables and then try
May 10, 2010 | Dell Dimension 2400 PC Desktop
Tower shuts off after it beeps on start up
It COULD be an issue with the video card or the memory. Try to remove and hook it up again. But make sure it will not loose.
Jul 20, 2009 | E-Machines eMachines Desktop PC
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
My screen is blank. The computer appears to be
Sounds like a driver problem. Hold F8 when it's booting and try Safe Mode
Jun 29, 2009 | Toshiba Satellite A135-S4527 Notebook
Beeps half-dozen times then shuts down.
try ur windows disk,,put it in and go from there,,reformat if u have to,,or try sytem restore,,
May 17, 2009 | Dell Dimension 3100 PC Desktop
Won't load windows...
you video card is not working.... if you have onboard video use that until you have installed the driver for your add on video card
Apr 16, 2009 | Dell Dimension 3000 PC Desktop
Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Jun 02, 2008 | Gateway GT5404 PC Desktop
Computers & Internet Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
