Question about Acer Aspire L100 PC Desktop
How to I change the battery on my acer aspireL100
The clock on my acer aspire is only working sporadically. I assume its the battery but I don't know how to change it. Can anyone tell me what to do please?
  • 1 more comment
  • Lassie21 Sep 19, 2008
    Well, my machine is a desktop not a laptop (aspire L100) so much of the above doesn't help. I reallly wanted to know if I take it into a shop or whether I can do it myself. I guess my request wasn't clear enough.
    Thanks for trying.
    KT
    Aha, thats getting closer - how do I get to it - do I unscrew the box ? Thanks so much for your help.
  • Lassie21 Sep 20, 2008
    Fantastic. Now I know what I need to know to change my battery. I am very grateful. This is a brilliant system and I will certainly use it again. Thanks for your help.
First, ensure that your power adaptor is consistantly powering your system and watch for intermittant operation with the adaptors green light. (This rules out cord breaks for shorts)
Second, all laptops have a removable battery: You can find a replacement at http://www.kahlon.com/batteries.asp
Laptop batteires serve to power your CMOS (Carbon Metal Oxide Semiconductor) on your laptop, and keeps your internal BIOS clock accurate. On Desktops, it's a lithium battery on the mainboard.
Also, check to ensure that you do not have a battery recall on the unit as well, as you may be able to get a free replacement.
If your clock is off by a few minutes, change time servers in the windows clock option. Just double click the time on the task bar, click internet time, and you can this one if you don't have it listed: nist.expertsmi.com Some are overloaded due to requests. That should keep you with arc seconds on the actual usno time clock.
Good luck.
Good luck.
Posted on Sep 16, 2008
  • 1 more comment
  • dgtechman Sep 19, 2008
    Ohhh, it's a desktop. My bad. It sounds like all you would have to do then is to replace the Lithium battery that's on the main board. Usually it's a walgreens cr2032 watch battery. Offtentimes what happens is that the boards sit in warehouses for a while even after being shipped from china and the batteries which gives the batteries time to drain down. Just pull it out and replace it with a new one. Fingers crosssed it's not soldered to the mainboard. =)
    There's usually 3 screws holding the side panel on. Just remove them and slide the left side back and off. (left if you're facing the computer). Be carefull about static electricity (the type that gets you when you walk accross a shag rug in the wintertime and touch a door knob) try to avoid touching chips and memory. All the current that runs through a mainboard is DC and not AC. But DO unplug your computer before you open the case! =)
  • michaelskeet Sep 02, 2011
    I have an Acer L100 mini tower unit in which the bios battery ran out. So to replace it without any available manual I had to carefully remove the top/side panel by undoing the single chrome headed screw holding the top/side panel and sliding the panel rearwards exposing the inside top drives plate over the motherboard. I then discovered 3 black painted philips head screws at the rear of the assembly holding the drives in place which covered the motherboard and concealed the internal components. Having removed the 3 screws and unclipped the plastic tabs holding the front panel in place, I was able to gently prise the drives section from the motherboard (taking care not to strain the ribbon cable connecting the drives assembly to the mother board) and then gained access to the bios (cr2032 watch battery) after replacing this with a new item I then carefully reassembled the unit and all systems functioned normally.
How do I change the clock battery on my acer aspire l100 desktop
Unfortunately, the Acer site is worthless as far as documentation, so I will just give you the generic answer and you will need to fill in the blanks. Typically, the clock battery used in computers is a lithium coin cell. Some systems have larger batteries, but most do not. You will need to open the case and find the battery on the motherboard. It should be about the size of a quarter. It will have a number on it. You should be able to find a replacement at your local drug store, kmart, etc. Just replace the battery and and ajust the clock and you are done.
Nov 20, 2012 | Acer Aspire L100 PC Desktop
My Acer Aspire 57342's battery is not working
plz change the batry no hardware problem only batry problem
Sep 09, 2011 | Acer Computers & Internet
Acer Aspire One D255E battery meter says 100% charged but computer shuts down when you unplug power cord
That's often the sign of a worn-out or defective battery. They appear to charge but don't store enough energy to work. It's also possible the motherboard's power circuit isn't working. The only way to know for sure is to have a known good battery as a test, or to try your battery in another computer. If your computer works with a good test battery, or your battery causes another computer to shut down, you know you need a new battery. If the trouble continues with a good test battery, you'll need to have the computer serviced.
Jul 03, 2011 | Acer Aspire One D255E13438 Netbook
I have a pink acer one computer does it have an alarm clock
Assuming that you still have the same Operating System (Windows XP) that came with the notebook, it does not have an alarm clock. Although you can download one from the following link: http://download.cnet.com/Alarm-Clock/3000-2350_4-10064069.html
Note: You will need to keep your notebook switched on the whole time in order for the alarm to work.
Jun 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
I cant change the language of my acer notebook the language of my laptop is japanesse
I will assume you are using Windows 7. To change to your desired language:
1. Click Start and go to Control Panel
2. Open "Clock, Language and Region"
3. Open "Change Display Language"
Feb 20, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer notebook aspire one
hello
If your power supply has gone bad and your system is under warranty and you can call the customer care of Acer and they will replace the supply or the mother board whichever is required.
or you may check ir yourself by
  1. trying a different battery.
  2. trying different charger.
If both these things are OK try system restore.
Thank you
Aug 17, 2009 | Acer Aspire One A150-1006 Notebook
My Acer Aspire 5630 shuts down by itself after about 10 minutes when I am on skype
I think the first thing you should check in the power save, Down by the clock, i know you can change how long your laptop is on to save power plugged in or on battery
Nov 30, 2008 | Acer Aspire 5610-4648 Notebook
Acer laptop sporadic fan/dvd drive noise
it is quite normal especially if you are running processor hungry applications, or down loading video files
Aug 23, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
My Acer Aspire 5100 clock keeps falling behind...
if the clock is consistently being resetted then most likely you have a failing cmos battery. you need to dismantle the laptop in order to have access to the cmos battery. you need to fina a COIN type battery.
Apr 12, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100-5840 USB Problems
Is your laptop still under warranty? I would go to the manufacturer first if it is.
If not:
the system clock is run by the CMOS battery. When low will cause a host of problems. Change it and let me know if this fixes your problem.
Dec 27, 2007 | Acer Aspire 5100 Notebook
Acer Aspire L100 PC Desktop Logo
596 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
