Question about Mitsubishi Televison & Video
I have the Mitsubishi HDTV 1080 series model. The picture goes off and on periodically. A message says to check commections or power--RGBHV or YPrP m be invalid. Any suggestions are welcome. Thank you. Frank
    Guru:
  • 1,894 Answers
See this link.
this is the similar problem as yours.
You could have a problem in the DM board assembly. First thing to do is open it and see if the DM power supply capacitors are swollen or bad. This could be a very costly repair unless you know how to solder and work on printed circuit boards. If you do not, play it safe and call in a pro to assist you in this repair. Good Luck
i know BDG has already posted the same post.
thank you
Posted on Sep 16, 2008
  • dewan nafees ahmed Sep 16, 2008
    this would help you i think
    Blinking Problem
    http://www.chrisandnat.com/Projects/Blin...
    http://www.jeremyburns.com/Mitsubishi-Gr...
    http://www.fixya.com/howto/h159332-mitsu...
    http://hdtvoice.com/voice/showthread.php...
    replace DM
    Picture of bad caps
    http://www.auctioncreations.com/wd62525a...
    thank you
    please post back if you need further help
  • 3,037 Answers
This looks like it could be a problem with the DM board assembly. First thing to do is open it and see if the DM power supply capacitors are swollen or bad. This could be a very costly repair unless you know how to solder and work on printed circuit boards yourself which if you don't, then take it in to get repaired. Be careful not to touch anything that you are not familiar with as the power in the unit can hurt you.
  • 2,326 Answers
What is the model of your TV?
Are you getting the messages on regular or HD video?
On my Mitsubishi HDTV 1080 series integrated, when I plug in the power cord the light on the front just keeps blinking and there is no picture or anything. Can you tell me what the problem is?
The DM capacitors have failed which causes the led to blink non stop green. Replaceing the DM caps will usually repair the issue. But need the model number of the set to assist you further.
Jul 12, 2011 | Mitsubishi Televison & Video
I have a Mitsubishi Projection 1080 Series TV. The picture sometimes (most of the time) is "bowed" at top and bottom and blurred. Sometimes corrected by repeatedly powering off and on.
okay, 1080 Series isnt the model... the model number is on a sticker on the back, and that's what you need to find first. Just from the description, though, sounds like your focus block is bad; that will cause the problem you are describing... not cheap, but way cheaper than a new TV.
Dec 11, 2010 | Mitsubishi Audio Players & Recorders
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
Jun 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Picture and sound go out and remote isn't working properly
Take the original Mitsubishi remote and remove the batteries. Install new fresh batteries and then try to operate the set. Do not try to use any of the inputs that are active. Just check menu funtions with the mits remote. All kinda irrational stuff happens when multiple and universal remotes get involved. If this a model remote that has a selector switch at the top for choosing tv/sat/vcr, etc make sure it's on tv.
May 28, 2009 | Mitsubishi WS-55515 55" Rear Projection...
Mitsubishi 1080 series, ws-65311 model
Same problem.. Checked the fuses but they're fine no reset switch to be found.
Sep 07, 2008 | Mitsubishi WS-65311 65" Rear Projection...
No Picture
the ligh egine has a thermostate on it wich stop it frrom coming on
Jul 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
May 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
