Question about Dell Inspiron 1501 Notebook
Thanks again... but can i ask more...so u mean to say it is still safe to use my battery even if there's a warning as i open my laptop...the AC you are talking about its the charger ryt?well i guess its safe to use...becauseryt now im still using it..is it okay that i ignore the warning about the battery?thanks its a big help...:-)
    Novelist:
  • 116 Answers
Sometimes, the battery alarm is set to high or off and it will automatically warn you when the battery is at a certain percentage. Most newer laptops will even warn you when the battery is going bad.
The AC cord is both the power cord and it will also charge the battery when plugged in as well.
So, it's safe to run on just battery as it may just be telling you that it doesn't have AC power and that you're running only on the battery. My Satellite laptop is setup to warn you when it's only on battery power as well.
Posted on Sep 16, 2008
Acer aspire e1-532 battery led off when plug the ac adapter and does not power up
It is beyond what I can diagnose remotely, as it fails to power up even on just the AC adaptor, without the battery.
It needs a professional repair, which means opening it up to find out why it fails to start or even show a screen, which means no software fix can be done.
Feb 05, 2015 | Acer Computers & Internet
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
Lenovo T61 Thinkpad not booting up
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally.
Thanks & waiting for your feedback
Feb 08, 2010 | Lenovo ThinkPad® T61 PC Notebook
HP laptop does not start.LED on.black screen "warning-battery low
Im not sure but there is normally a button somwhere on the laptop which acts a a reboot button. normally very small and have to press it using a pin etc. You could try that then turn it on but not sure if it will help?
Jun 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
"Plugged in, not charging", Toshiba Satellite A135 S4527, under Windows Vista Home Premium
I started having the same problem and worse mine would shut off without warning either from the battery running down or even just plugged in without a battery.
I thought It might be overheating so I got a can of air and cleaned all of the vents...and downloaded core temp to monitor the cpu temp @ http://www.alcpu.com/CoreTemp/. Same problem shut down and no charging even though it was running cool.
Finally I started changing settings and it seems to be working and charging just fine.
Here's the answer:
1. Set your power scheme to balanced
2. Open Toshiba Assistant from start
3. In Toshiba Assistant open CPU tab and set to low power.
4. When asked "restart now?" say no and shut it down using the start menu.
When you start it back up you will see the change.
Changing either one of these settings brings the problems back. I can't explain it.
I HOPE IT WORKS FOR YOU!
I just can't afford another laptop right now.
P.S. even at low power my system works fine...It's a little slower @ start-up but otherwise good.
Sep 30, 2008 | Toshiba Satellite A135-S4527 Notebook
Is it safe?
It's safe to use with the battery that way. Do you have a power cord for it?
Sep 12, 2008 | Dell Inspiron 1501 Notebook
Is it safe to use the battery?
ya absolutely no problem with that
Sleep State Resume Trouble
Yes, unplug, remove battery, replace, then start. It's just glitched slightly, no biggie.
Aug 09, 2008 | Dell Latitude D600 Notebook
My laptop turns off in AC Power. Please help..
Windows 98 questions and answers AC, Additional help and information on autoexec.bat / config.sys. APM, Issues and help relating to Advanced Power Management.
Computer Power Supply Information WARNING: Do not open the power supply, it contains capacitors which can hold Electricity (WHICH CAN KILL) even if the computer is power off for a week.
Be careful , Good Luck, Please dont for get to Vote/Thank You.
Dec 26, 2007 | Fujitsu LifeBook B2131 Notebook
Dell Inspiron 1501 Notebook Logo
66 people viewed this question
Alun Cox
