Install primary cover and gasket using the sixteen screws with captive washers tightening in sequence from center to front alternately top then bottom the middle to rear alternatively top to bottom to the rear of the cover to 100-120in-lbs (11.3-13.5 Nm) in sequence.
what clutch fastener information do you want? Post a comment if you need more information.
What clutch
SOURCE: 1982 Harley davidson shovel head , i need the
I always pull them to 70 foot pounds in a criss cross pattern. Start the engine up and allow it to warm up. When cool, retorque the heads in the same manner. I only use Fire Ring head gaskets.
Good luck
Steve
SOURCE: 1998 harley davidson softail custom primary cover bolt pattern
Are u asking for the torque sequence for the outer primary cover ?
SOURCE: Need the torque specs on clutch for a 85 FLHTC
The torque specs are the same as with any Evolution engine. The compensator sprocket 150-165 foot pounds.
Clutch hub nut (left handed threads) 60-80 foot pounds.
Use Loctite 271 on threads. Two lines in nut on Compensator and one line in clutch hub nut.
SOURCE: need to replace clutch 1986 fxrs harley davidson
replace the old oil with no more then 1 quart of H-D Primary Oil.
SOURCE: what are the torque specs on a 2001 harley fat boy
Maximum Torque: 106 Nm (78.2 ft. lbs) @ 3200 rpm
