Question about Mackie SWA1801 Subwoofer
Swa 1801 mackie blown capacitor
I have a blown 100v 5600 capacitor in my mackie 1801,where could i get one of these,ive alredy tried rs
  • Anonymous Oct 08, 2008
    I have the same problem and also can't find any to purchase. Can anyone help?
  • n12sailor Nov 15, 2008
    i have the same problem as well, not been able to find the capacitors any where! help appreciated.
Mackie 1801 f 1 blow and tip 122 bad
Posted on Mar 05, 2012
Digikey # 565-2717-ND is where i get them
Posted on Jul 11, 2009
Took alot of finding but you can get them from Digi-key
Posted on Dec 03, 2008
Hi sorry it was mackie srm 1801 works fine on A out put can I use for time all is working well
Yes, you can use the A output, as long as you're OK with it being a mono system. It may be helpful to read the manual which has a lot of info including possible setup configurations. Here's a link-
http://www.mackie.com/products/srm1801/pdf/SRM1801_OM.pdf
Mar 28, 2015 | Mackie SRM 1801
My mackie swa 1501 when you plug in no power checked the outlet their is power checked power cord good. what can i do
There are many possibilities, the switch, motherboard, electronics etc. If you are a DIY kind of person and you want to try trouble shooting yourself, you need tools. Better still, take it to a service person/ outlet to proper checks.
Oct 06, 2014 | Mackie SWA1501 Subwoofer
Please show a list of kenmore sewing machine manuals
This should be most of the Kenmore sewing machine manuals.
010
1020
1030
1040
1045
1050
1206
1230
1232
1240
1250
1300
1357
1430
1431
15/I649
15243
15343
15358
1625
1641
1660
17920
17921
17922
1940
1941
1947
19501
19502
200
38
385.17622
385.19000
385.101118
385.115518
385.11607
385.11703
385.12614
385.15202
385.15208
385.15243
385.15343
385.15358
385.15408
385.15512
385.15516
385.160201
385.16120200
385.162213
385.166551
385.16677
385.16765
385.19005
385.19365
519
ELITE
14
1500
15218
15616
15718
1600
1650
1651
1652
1654
1750
1791
18
385
385.17620
385.17624
385.17630
385.1 521 2
385.115418
385.12314
385.151082
385.15358
385.161302
385.19005
68
95
96
SWA/RS 10101
SWA/RS 11101
SWA/RS 12551
SWA/RS 12621
SWA/RS 14401
SWA/RS 14501
SWA/RS 14502
SWA/RS 14571
SWA/RS 14572
Oct 02, 2014 | Kenmore Sewing Machines
Model swa 1801 Fuse 240V 4A burned out ! I replaced it but still get no power (any led stay off) What can it be ?
check for integrity of the main amp and the torroidal transformer.
here is a guide , how to check for transistor
if there is a continuity on the primary terminal of the transformer.
Have a tech to guide you , should you need to DIY.
Sep 17, 2011 | Mackie SWA1801 Subwoofer
Can you tell me what the impedance is of the SWA 1801 speaker?
As per spec sheet states:
Input Impedance = 50K for the Active System
SWA1801 Active Subwoofer Spec Sheet - Mackie
For the passive speaker =4 ohms
Sep 14, 2011 | Mackie SWA1801 Subwoofer
The Amp on Mackie SWA 1501 sparked and burned today
I don't think the amps are available from Mackie any more. You can have it fixed: www.alivesoundcenter.com
Nov 26, 2009 | Mackie SWA1501 Subwoofer
Mackie swa 1801 power amp R7 100 ohm resistor smokes when powered up..
You likely have other parts blown as well, but Q3 (MJE15033) AND/OR r8 (1 OHM/0.5 Watt) are blown. I suspect that Q3 has a base-collector short and you will find several of the output transistors are fried as well Q4, Q5, Q15, Q16. I suspect that the Zeners D14, D25 may be blown.
When restarting this, put a 100 Watt lampin series with teh 120 volt power to limit current and avoid destroying freshly repaired parts due to a few bad ones not found.
Aug 17, 2009 | Mackie SWA1801 Subwoofer
Signal light stays on, no sound output
T14 is part of the +15v power supply that feeds the input board.
It is actually a transistor.
If this is the only problem on the board, then this transistor could be resoldered back on but you will have to make sure it tests OK and it attaches to the heatsink the same way it came off. ie make sure it is electrically isolated from the heatsink
It seems if there is no fuses blown on the power amp board you might be one of the lucky ones.
In my opinion this amp is a clever design but is under-engineered for robustness
Aug 09, 2008 | Mackie SWA1501 Subwoofer
Mackie SWA1801 Subwoofer Logo
1,010 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
