Goodmans dvd gdvd306r -disc error - Televison & Video
  • keithwalshe Nov 24, 2008
    It plays region 2 fine but when i put in a region 1 any music or background sound is heard but no voices
Hi i've think i managed to fix my machine. With the disc tray open enter setup and go down to the third option and change the sound to stereo. Hope it works
Posted on Nov 24, 2008
DISC FORMATS??will not play some disc
There are some DVD players that will only allow the store bought discs to work on their system, probably due to copy right infridgements.
May 08, 2012 | Goodmans Televison & Video
No display
Since there is only the power light on your set the SMPS of your DVD seems to work. In such a case it is important that you will have to check on the electronic circuit . Hence if you are familiar with electronis please check accordingly on the power and the main boards. You will have to check for all the power coming out of the power supply unit. The + 5 to the main mP of the main board controlling the panel controls also should be checked for working of the mP. If you are not familiar then get help from a friend with working knowledge to trace and if you find the main board faulty it is important find out the cost before thinking of changing as the prices of new sets arre pretty down . Hence you can confirm and decide accordingly. Hope this advice help to decide. Good day
Jul 18, 2010 | Televison & Video
Goodmans gce 5007 portable car dvd player. disc bay is empty but still will not load disc
ANYONE GOT SOME LEADS OFF A FAULTY GOODMANS GCE5007 I CAN PURCHASE? KINDEST REGARDS
Feb 26, 2010 | Goodmans Televison & Video
Disc Error on Goodmans ghd8015f2.(Freeview HD Digital Recorder)
Yes, you can install another 80GB Hard Disk Drive.
The copper plates can be fitted to the new hard drive.
You can format it FAT or NTFS.
Nov 25, 2009 | Computers & Internet
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
No disc
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
Mar 07, 2009 | Goodmans DVD2100B DVD Player
Dvd recorder not formating after recording.
My Sony DVD recorder RDR-GX 350 not formating the DISK to enable me to record.What`s the problem with it? Thanks.
Dec 28, 2008 | Televison & Video
Goodmans home dvd recorder
Make sure the DVD has been finalised. When you finalise a DVD the recorder puts all the disc content information at the start of the disc so that any device you put it into can find out what is on the disc without scanning through 4.7 Gigs of data, (which would take so long it would drive people mad everytime they put a disc into anything). Because the table has not been written the PC cannot see what is on the Disc.
Another possible answer: some makes, Orion for one have a Virtual Record mode that it was not possible to play in any other device.
And Orion do make products for Goodmans.
Most likely the first answer though.
Feb 17, 2008 | Sony DVP-NS530 DVD Player
Goodmans portale dvd player
When i insert any cd or dvd massage comes on screen is 'NO DISC'
Sep 01, 2007 | Goodmans Televison & Video
Televison & Video Logo
304 people viewed this question
Top Televison & Video Experts
Electro Med Services...
