Question about Hoover Washing Machines
Washing machine slowly fills with water when it`s standing idle - whether turned on or off !
    Genius:
  • 1,028 Answers
Replace fill valve..if screen become blocked and reduce remove clean and reinstall do not leave out or the problem you have now can reoccur
Posted on Sep 16, 2008
We have a LG Fuzzy logic 5.0kg WF-T507. When not working, cold water is slowly leaking into the tub. The hot water is also not flowing when needed.
The fill valve could be defective but the leakage into the machine when idle could be caused by supply line(s) above the fill valve level. Some manufacturers recommend turning off the supply between wash sessions but in practice that tends to be impractical.
Feb 12, 2017 | LG Washing Machines
Washing machine bowl slowly fills with cold water whislt standing, off
replace the stop solenoid control unit in the machine or make it a practice of turning he tap off at the wall
the small diaphragm in the unit is leaking --probably has a small split in the rubber
Jan 18, 2016 | Washing Machines
What does LF stand for on a Whirlpool Washing Machine?
LONG FILL....I usually means the faucets are not turned on fully OR you have a pinch in the hose and it is taking too long to fill (LONG FILL).
Jun 02, 2015 | Whirlpool Washing Machines
Washing machine (F&P 380) - does not fill with water very quickly.
THIS SEAMS TO ME LIKE WATER PRESURE KEEPS DROPPING DEW TO LOW WATER PRESURE IN YOUR AREA OR YOU HAVE A KINK IN THE PIPES TO THE WASHING MACHINE
Aug 12, 2012 | Fisher and Paykel Washing Machines
Bowl keeps slowly filling with water when turned off.
I think your water valve is bad , change it
Aug 12, 2009 | Washing Machines
Bosch washing machine
You have a sticking water inlet valve, which is slowly letting water enter m/c.
If it is a hot and cold fill m/c, what you need to do is turn either the hot or cold tap off to the m/c, and see if the problem continues, if say you turn the hot off and it still comes into the washer, then you have sticking cold valve, replace with new one. if after turning cold off, and it still fills, then you need new hot valve fitting.
If it is a cold fill m/c only, then simply replace the cold inlet valve.
Problem solved.
Plz rate my solution.
Thanks.
Dec 21, 2008 | Washing Machines
Washing machine
You have to check whether the water flow is good from your tap in the wall. Then check for blocks in the hoses; there are screens also in the machine (at water entry) which should be cleaned up.
Rate me pl.
Dec 05, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines slowly fills with water over a few days
could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Mar 17, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
60 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
