Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Replaced caps still have the blinking light
  1. I had the same problem and replaced the CAPs on the DM board but I still have the problem. Can someone send me the soluction cdigou@hotmail.com
  • cdigou Sep 16, 2008
    I'm not sure what else to add. I have the Mitsubishi WS-65513 that had the constant blinking light problem. I replaced the CAPs on the DM board and tested the fuses on that board and I still have the same problem. I need some direction on what to try next.
  • Mitsubishi Master
  • 5,568 Answers
Since you didn't add your message to the original one, I don't know what you have already tried or any other details so - If you can find the original thread, post the link to this one.
If a switched mode power supply is cycling, it is either ill or it is preventing further damage caused by a downstream problem by not allowing full operation.
I don't think anyone can send you a solution unless it is a known problem with particular models.
Posted on Sep 16, 2008
Mitsubishi green blinking light of death
Hi Jim,
Green blinking light of death on Mitsubishi DLP TV means that the DM failed to booted up. I would advice you to replaced the 7 1000uf electrolytic capacitor on the DM board. Most of the time it fixed the symptoms. Please inquire at tvrepairworld.com if they have an available DM repair kit for V36 chassis (WD-57733 chassis).
Jdvillanueva
Jan 10, 2012 | Mitsubishi WD-57733 57" HDTV
Timer light just blinks. I removed buttons from
A continuously blinking green light is almost always caps on the dm board.If you have access to an esr meter check them that way and replace.
Nov 10, 2009 | Mitsubishi WS-48613 48" Rear Projection...
Mitsu wd-52628 green flashing timer/power light
steady blinking is the DM failing to complete the boot sequence. Your more than likely needing the DM repair kit.
Jun 18, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mits 52525 blinking green light
Good Day;
If you only changed 4 caps,1000 ucfd 35v, it should be 5, if you did not remove the little plug in board, e prom, you may have damaged that. B-4/after changing caps what is the indicator light, green, doing?
Does light stop? Please rtn with more info.
Jun 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I need help with my wd-52525
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
May 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green light will not stop blinking
often the capacitors will show no visible sign of swelling. 90% of the time the blinking light symptom is caused by those capacitors
May 12, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Blinking light will not turn on
replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
May 06, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Have mitsu model # ws-65813 wont turn on
You have a common problem in the DM (Digital Module), more specifically the DM power supply. There are four electrolytic caps in that supply 16v/1000uf that are bad and likely buldged from heat stress. Replacing these caps and the E2P module, a small stand-up board further back on the main DM board should restore normal operation...
You might be lucky enough to have a tech come out and simply replace those caps in-home. It's not a really big job for a qualified tech.
Hope this helps!
Bill
Dec 01, 2007 | Mitsubishi WS-65813 65" Rear Projection...
Please send capacitor replacement info
know problem of bad caps.
replace DM
Picture of bad caps
Nov 01, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Help my ws-55511 can anyone help me with this.
Changing caps on DM board is good prevent maintenance,
 but does not represent the solution...DM caps symptom is
 Continuos blinking light.
 See    " problem 351"    On 10/20   WS 55908  comments.
  Let me know....T.
May 16, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
