Question about Car Audio & Video
1994 lexus ls 400 radio reads err when i try to play cd changer.
  • harley247 Mar 11, 2009
    my 94 es300 cuts out when engine gets warm, changed fuel pump and did not help, have to let it sit for 30 mins cool off and it will crank again go 4 or 5 miles and cut out again, what do i do ????
Hi
How can I find the code for my 1994 Lexus LS400 radio.
Please replyat : shahramanwari@cox.net
With regards.
Posted on May 11, 2009
CD CHANGER SHOWS ERROR 21
This may be an indication that the CD player has worn out and needs replacement.
May 11, 2013 | Car Audio & Video
Radio doesn't work and all the fuses are good
Check radio ground. It should be grounded to vehicle chasis behind the radio. Also check if power is on the wire at the rear of the radio, maybe a bad wire. These are good places to start troubleshooting. Good Luck.
Feb 07, 2013 | 1992 Lexus Ls 400
What station does my radio need to be on in order for my 92 lexus ls400 need to be on so i can play my cd's????
if your car equiped with separate cd changer ,which usually in the trank , then in the head unit push CD button , then you'll be able to control and play CDs.
Jul 02, 2010 | 1992 Lexus Ls 400
Need to remove cd changer in the trunk
pull the trunk lining out and remove the 10mm bolts holding it in. the trunk lining is just held in with plastic clips.
Sep 02, 2009 | 1994 Lexus LS 400
DASHBOARD LIGHTS OUT ON 1994 LS400 LEXUS
check ur fuels thats usually the problem and its very in expensive
May 27, 2009 | 1992 Lexus Ls 400
1994 lexus ls 400, cd player
Hello I just purchased a 1991 Lexus LS400
I have one of those 6 cd changers and got "err" when I started up the CD.
Here is what I tried and the result
1. I took out the CD,s replaced with new ones and it played but only for a bit, then even the new CD's got the err message
2. I then though maybe dust and/ or dirt so I took out the 6 pack of CD's and blasted compressed air into the unit from a can of computer cleaner compressed air. Lost the err message but then came back
3. Read a few other ideas on the problem and then tried the old hair dryer trick. (I am a long term live a board boater and have brought back may mis-behaving electronic devices that have moisture issues with the hair drier) However the hair drier did not do away with the err message.
4. two more boating tricks I thought of... I wiped down each leaf of the CD pack with rubbing alcohol
and actually got a good deal of dirt off the plastic, finally and probably the solution I sprayed some "wire dryer" a light spray then a mist.( Wire dryer made by Gunk is a spray can of a liguid we used all the time to get cars started in the cold weather, even got a better connection by spraying on battery wires to get the sailboat diesel started with an almost dead battery.)
I Waited a few minutes put back the cd holder and it worked.
It has been about 6 hours and it is still running like a champ.
could have been the combination or just the wire dryer...not very scientific maybe it will help
Jan 12, 2009 | 1993 Lexus Ls 400
1992 6 disc cd changer not working
Are you placeing cds face up or face down in the changer, some cd changers will only play with the cds face down.
Oct 26, 2008 | 1992 Lexus Es 300
Lexus Cd-Changer
lol had this prob so many times, you will find that you have moisture in the cd exchanger and the way i found this out was on removing my cds first thing in the morning a noticed very slight misting on most of the cds. .i put the wifes hair dryer and blasted warm air into it for a good 15 minutes waited till it cooled down cleaaned carefully my cds replaced and away i went. hasten to add that this was temporary a few days later i got the odd cd not playing . i notice the prob more in cold weather and if the car has not been used for a few days. the boot maybe damp .. good luck .stu
Aug 19, 2008 | 1996 Lexus LS 400
Radio locked 1991 lexus ls400
do you know how to reset radio code lexus ls 400 /1991
Aug 14, 2008 | 1991 Lexus LS 400
Car Audio & Video Logo
382 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
