Question about Sony Ericsson K800i Cellular Phone
Touch Screen/Buttons don't work
The three touch screen/buttons on my phone have stopped working making navigation and use of the phone impossible as the automatic keylock is on. To turn off need to disconnect the battery and can only make a call if I quickly turn the phone on and make the call before the key lock comes on. Have removed the outer case halves but can not see any obvious problems with flexi circuits. Any suggestions?
Its need new key pad
Posted on Sep 16, 2008
I'm in Malaysia . My samsung f480 touch screen is not working at all ... but the down three button is working ... what should i do ... ?
I recommend doing a hard reset on the phone (You will loose everything on it currently). I had a very similar problem with my phone, but the reset fixed it. I couldn't reset my phone through the preferences because the touch screen didn't work. I figured out this other method: 1. Power off the phone, 2. Hold down the lower volume button+power/sleep button, 3. Keep holding those two buttons until the phone comes up with a menu, 4. Use the up and down volume buttons to navigate the menu to: wipe data/factory reset and press the power/sleep button (to select), 5. Navigate the menu to: confirm and press the power/sleep button again, 6. It should do its thing.
SOME OF THE MENU NAMES MAY BE SLIGHTLY DIFFERENT. If you are confused by my instructions or something is wrong, please let me know.
-Mr. W
May 05, 2014 | Cell Phones
All of my buttons are frozen, phone starts up via
Hi There,
I believe that the ribbon attaching the keyboard and the screen may have become loose,that is why you are not able to make inputs to your screen. If your fone is still under warranty you should get it replaced as this is a manufacture fault.
Oct 28, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Touch buttons not workig?
DEAR IF THERE IS NO PROBLEM WITH FLEXI CABLE THEN THERE IS SOFTWARE PROBLEM,TRY TO FLASH IT
Aug 05, 2009 | Sony Ericsson K800i Cellular Phone
My sonyericsson k850i touch screen is not working
Sir, try reinstalling your phone. This will make the phone to be back to its original settings and maybe can bring the phone's touch screen capability back.
Jul 19, 2009 | Sony Ericsson W850i Cellular Phone
Touch on touch screen phone not working
Hi, I have the HTC touch from bell. I too had the same problem with my screen. It stopped working completely. The phone is pretty much useless without the touch screen working, there is only 3 buttons on the phone! Can't even dial 911... So I was pretty pissed when the screen stopped working. Like others I searched the internet for answers and didn't really find too much. I found that maybe tapping the four corners of the screen firmly might work, but it didn't. Taking the protective cover off the screen might work, didn't work. I tried updating the ROM, using the official software from HTC website. I was able to update my phone, but my touch screen still didn't work. Someone said something about some copper connections inside the phone, need to be re-adjusted behind the screen or something like that. So I willing opened the phone (only 4 hex screws on the back) and took the front plastic cover off. If you look closely, you'll see the front cover is plugged into the 'motherboard' and you can simply unplug it. I unplug it and plug it back in, do a restart of the phone (take battery out and back in) and still nothing, screen doesn't work.
I noticed that on the front cover of the phone (underneath) you can see the copper band of wires that connect to the buttons and probably feeds the information from the touch screen to the 'computer'. I accidentally unplugged the wire (thought I broke it) but was able to insert it back in. I put the the cover back on, put the battery in, power up phone, BINGO! Touch screen works! What I did to make it work? Not sure...
But for people with the same problem. Try this:
1) update ROM
http://www.htc.com/us/SupportDownload.aspx?p_id=70&cat=2&dl_id=98
2) Unplug and plug back in that little wire.
http://img81.imageshack.us/img81/1912/htctouchx.jpg
Its the red circle I'm talking about.
Jul 07, 2009 | HTC Touch Cellular Phone
Bottom screen wont work
Have you attempted to recalibrate the touch screen?
Since you can still use the navigational buttons,
From the main menu:
1. Click the "Settings" button. It is the button at the center bottom with the DS on it.
2. Then click the "Touch Screen" button. That is the one with the Yellow Crosshair on it.
After that, proceed to calibrate your touch screen.
Let me know if that does not work.
Dec 09, 2008 | Nintendo DS Console
My touch screen is not responding
My touch screen has not been responding but my navigation buttons are working. I'm not able to check my contacts too.. .
Oct 27, 2008 | Motorola Mobility MOTOROKR E6
Touch Screen 'Back' button on my K850i affected by every other button.
problem solved. i had the same problem but i fixed it somehow. one day i just took a iron thick pin and pressed the space between number 5 and left-down button(not in the gap). and then i pressed between left-down key. Instantly it started working fine. i dont know whether it was my luck or i just accidently found a solution.756425f.jpg
Jan 23, 2008 | Sony Ericsson W850i Cellular Phone
LCD screen will not respond to touch
First of all examine the LCD connecting flexible strip. If faulty or broken, let me know. Sivaram.V videolabs@gmail.com
Jan 08, 2007 | Sony DCR-HC18E Mini DV Digital Camcorder
Sony Ericsson K800i Cellular Phone Logo
115 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
