Question about iLO DVD Recorder DVDR05
Recording on DVD using converter box
I can't find much information on recording TV programs using a DVD recorder and a digital converter. Does anyone have information on how this will work and what the limitations are ? I have read that if I want to record a program the converter box needs to be left on and tuned to the channel I want to record, what if I want to record two programs on different channels ?
  • ABL_DIGITAL Dec 10, 2008
    I NEED TO KNOW HOW TO PROGRAM THE ILO DVD RECORDER TO RECORD THE DIGITAL SIGNALS COMING FROM MY CONVERTER BOX. I CAN RECORD THE DIGITAL SIGNAL THAT I AM WATCHING. BUT I WANT TO PROGRAM THE ILO RECORDER TO RECORD DIFFERENT SHOWS ON DIFFERENT DIGITAL CHANNELS AT DIFFERENT TIMES WHEN I AM NOT PRESENT. SUGGESTIONS?
I have my video outs from the converter box going to the inputs on the ILO recorder, and then from the outs on the ilo to the ins on the tv. Yes, box must be on and used to tune in what I want to record. I have successfully recorded this way. I never use the timer on the ILO anyway, it never works so If you want it to change from one channel to tape another you will have to be there. Also one of my box automatically turns off at a set time on non use so that is another problem. Maybe the newer recorders are differently programed but most cheaper ones don't have tuners in them so I assume they are about the same as what we have. Mostly for people who have paid tv now I guess. I refuse to pay, converter box is great.
Posted on Sep 20, 2008
Digital convertor
Do you mean the Samsung DVD-VR500E? The following steps should work for most DVD recorders. (In the US, you use the AV Input with an RCA composite cable or the RF input.)
If you get a digital-to-analog converter (set top box) and your current antenna provides the OTA signal at your location, then yes you will be able to record a digital program. Connect the set top box to AV1 or AV2 (the SCART inputs). Then use the Input Sel (under PR mode) to select the input. (Alternatively, connect an RF modulator to get the signal to the coax input from the STB to the recorder.) See page 75 of the manual for the DVD-500E for details on setting the input for recording: http://downloadcenter.samsung.com/content/UM/200410/20041023105238671_00500A-VR300E-XEU-E-B.pdf . Some DVD recorders only record on the TV (coax) input. In that case, you will need a set-top box with a RF out or an RF modulator but you can still record the digital program.
A dual tuner set top box will let you watch one program and record another if both the TV and the recorder are connected to the STB. If your TV has a digital tuner, you can split the incoming antenna signal to go to the set-top box and the TV. (Then you can also watch one program and record another.)
I prefer to use a switch instead of a splitter to reduce the signal loss. However, this forces me to record the program that I am currently watching. Since most of my recording is for time-shifting, this doesn't cause me a problem.
This site, http://www.ricability-digitaltv.org.uk/pages/products/stbs/stb_search_results.asp , has a list of reviews of set-top boxes for the UK. I know in the US, it is harder to find new converter boxes. However, they frequently show up in the used market as people replace their older TVs. This may apply in your region as well.
I hope this helps.
Jun 01, 2012 | Televison & Video
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
How do I record a tv program with a Sharp A400 VCR? Videos will play on the tv, but I was not able to get it to record. Thanks.
Your VCR is no longer capable of recording "off air" tv signals. All tv stations are now broadcasting in digital format, your VCR is analog only. You can however get a digital converter box that will receive "off air" digital signals and convert them for recording on your VCR. CLICKING HERE will give you all the information you need to hook up the converter box... Good Luck!
Nov 10, 2009 | Sharp VC-A410U VCR
I HAVE A 4 YEAR OLD PRESIDIAN DVD/RECORDER. I CAN
I SHUT THE CONVERTER BOX OFF BEFORE TRYING TO START RECORDING
Sep 30, 2009 | Dual Presidian DVD Recorder
Timer record on vcr/dvd attached to digital convtr box
You have to set the vcr to channel 3 or 4 (whatever the converter box is set to broadcast on). The signal to record has to come through the converter box. Since the VCR only has a analog tuner, it cannot pick up any digital channels on it's own.
Mar 29, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
Record to vhs with converter box
I need to leave my TV on channel 3 and set the converter to the channel I want to record. When programming for future recording, it's always from channel 3, not the channel I want the converter displaying.
Jul 17, 2008 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
iLO DVD Recorder DVDR05 Logo
166 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
