Question about Samsung AS18A6RB Air Conditioner
Samsung split AC indoor unit, front panel no display, AC does not work
Problem in Samsung split AC indoor unit Model AS24WA. Front panel display does not work. Samsung technicians changed both PCB's - diaplay PCB and dc power generating PCB that connects to mains and display PCB. Checked temperature sensors too. Problem is not solved. Any solution ?
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
  • 15 Answers
SOURCE: AS09WHWE try this link and please read it carefully, this gives you the advantage especially when all your appliances warranty expired.
Posted on Dec 12, 2007
  • 13433 Answers
SOURCE: Sensor in my Samsung Split
The receaver is most likely broken?
Posted on May 24, 2008
SOURCE: Samsung 1.0 ton(split) AC stops working during 36-37 degree C.
i believe you have a high pressure switch on your condenser that is going bad .it is a switch that has two red wires connected to it inside your outside unit
Posted on Feb 11, 2009
  • 10 Answers
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
Posted on May 31, 2009
How to replace the blower in a Senville SENA-24HF Mini Split Wall unit?
You have to pump down the a/c and remove the indoor unit. If not
The bottom of front side of front panel there are 3 screws. Unscrew and remove the front panel. Then unscrew PCB board. Then Unscrew the coil, and slightly keep upward and replace the blower.
Sep 08, 2015 | Senville 24000 BTU Energy Star Ductless...
I have samsung split ac 1.5 ton 2.5 years old when am switch on the ac the indoor unit is working when it tires to on the out door unit after 3 minute delay suddenly the ac is restarting but the out d
Make sure all of the pressure switches are closed on the low voltage control circuit on the outdoor unit. If any are stuck open, the compressor will not kick on. Or just push the compressor contactor in with an insulated screwdriver to ensure the compressor does actually work.
Dec 28, 2014 | Samsung Heating & Cooling
How to clean and service the voltas vertis platina split ac?
The filter is behind the front panel on the indoor unit. Look for a thumb or finger grip at each side of the panel and lift the bottom of the panel out and up. The filters should be seen as soon as you lift the panel. The filters will slide out. Wash them under running water by hand. Don't scrub , vacuum or brush them. They are quiet fragile and any harsh scrubbing will damage them. Cheers.
Mar 27, 2014 | LG L1204R Air Conditioner
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
How to clean the filters in split airconditioners
Check on top of the indoor unit. On some models, the filter will slide out from there without having to open the cabinet. On others you will need to pull on the top front and the panel will swing down (it will be hinged) and the filter will be behind that panel.
Mar 24, 2010 | Heating & Cooling
LG 18000 ac leaks water in the front of unit indoors.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
Can not switch on home air condition with remote and no have manual switch
If you open the front panel of the indoor unit (it opens upwards) near the receiver there is a samll on/off push button (switch). If the indoor does run but still cannot be controlled by the remote, there is a reciever board problem. you need to call their servicemen.
May 28, 2009 | Cfm Daikin R410a Split System Air...
Samsung AS18A6RB Air Conditioner Logo
519 people viewed this question
Top Samsung Heating & Cooling Experts
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
