Hi bpur04...
You have either a bad drum felt seal and or noisy or faulty drum rollers.
You will need to disassemble the drum assembly to replace your felt seal and your drum rollers.
I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
I am also going to include a link for you to download a user manual for FREE.
Please take time to rate me thumbs up
http://www.whirlpoolappliances.ca/assets/svXmW8P-TLAIvzVs3DbbPjHfLrBQ74kI.pdf
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
