Question about Canon imageCLASS MF5550 All-In-One Laser Printer
Changing the ink toner in a Cannon Super G3
We can't find a way to get out the ink toner cartridge. So we can change it. If you have a way please tell us.
  • HKAPUNAN3RD May 11, 2010
    lots of toner available in sthe store x-25
SOURCE: Ink level counter disabled, not recognizing new (refilled) cartridge.
Reset CANON MP 160 INKTANK
1.
unplug the power cord
2. press and hold down the <ON/OFF> button and reconnect the power cord
3. press the <STOP/RESET> button 2 times and then release the <ON/OFF> button
4. Display LED show "0" press the <+> button 1 time Display LED show "1"
5. press the <Start Color > button 2 times and then press the <ON/OFF> button waitng for testing out 2 pages
6. Open the cover. The carriage that holds the ink will move to the left hand side. and then unplug the power to the printer
7. Push down on the end of the black cartridge. A clicking noise will be heard.
8. Slide the cartridge out of the holder towards you.
9. Push down on the end of the color cartridge. A clicking noise will be heard.
10. Slide the cartridge out of the holder towards you.
11. Once both cartridges are removed, unplug the power to the printer (without turning it off).
12. Reconnect the power cord.
13. Turn on the printer.
14. Open the cover. The carriage that holds the ink will move to the left hand side.
15. Place the black cartridge in the bottom of the printer.
16. Slide the black cartridge back until is cannot go back any further.
17. Push up on the end of the black cartridge, a clicking noise should
be heard.
18. Place the color cartridge in the bottom of the printer.
19 Slide the color cartridge back until is cannot go back any further.
20. Push up on the end of the color cartridge, a clicking noise should
be heard.
Ya! YA! NEW
Posted on Jan 17, 2008
ctf1800
  • 4402 Answers
SOURCE: change ink cartidges
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Posted on Jan 22, 2008
leroyal
  • 2120 Answers
SOURCE: toner cartridge
RTFM
Posted on Jan 28, 2009
yooperbud
  • 8637 Answers
SOURCE: cannot align ink cartridges in my cannon mp160 printer
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
ThiruBulls
  • 103 Answers
SOURCE: cannon ink jet quit printing black
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel. # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right). # Continue doing this until it looks clean. # Then dab the cartridge on the towel to make sure the ink is flowing. # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier. 2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Aug 21, 2009
On my Cannon runner 5570/6570 why my printing jobs come out too light?
If it's a reconditioned toner cartridge.. Then it's fine. It won't be as original cartridge ink.
If new check setting there will be option - Save Toner, unselect this option
Nov 13, 2015 | Cannon Office Equipment & Supplies
Changed toner cartridge and now keeps stating error...change toner cartirdge
In the menu on the printer have it run a thorough cleaning on the print heads. Should be in the set up menu.
Nov 13, 2014 | Brother PPF-5750E 33.6K bps Super G3 Fax...
I have a fax machine Cannon Super g3 laser class 710 showing a system error E100, what does this mean?
toner cartridge problem! check the actuator from the drum cartridge! maybe broken.....
May 07, 2010 | Office Equipment & Supplies
I just changed the Toner cartridge and got an E100
A E100 is a Laser code... Look to make sure that the toner lever is in the correct potistion and that the front door is closed all the way and correctly.
Jul 23, 2009 | Office Equipment & Supplies
If we already changed ink cartridge, why would the toner still be low?
have you bought non compatible cartriges i have that problem after replacing epson inks i have the orange light on all the time now
Jul 13, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
My Cannon Super G3 says wrong page size
Open cover, remove toner, close cover.... not sure why this happens, but this is the only way that we have found to get around the error. After doing this 3-4 times, it seems to reset itself and work just fine.
Nov 26, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon super g3
Says "Toner is not set" near new cartridge. Any help appreciated!
Dec 23, 2007 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon imageCLASS MF5550 All-In-One Laser Printer Logo
1,291 people viewed this question
old marine
old marine
