Question about Philips Lands Phones
I have a ID937 telephone &I am having problems changing the outgoing message.I cannot find a menu which says Record message,although this is indicated on page 54 of the user manual.I must be honest @ 75 it must be my fault. Cn you please help an old man.
I solved the problem by reading the preceeding page.As they say " Theres no fool like an old fool.
Thank you anyway.
Jim McIntosh
Posted on Sep 17, 2008
How to change voive message
Press MENU until you hear "Record Outgoing Message."
Press REC/MEMO. The voice prompt will say "Now recording", following by a tone.
Begin speaking after the tone, towards the front edge of the Base Unit. The Base Unit display becomes a timer as you record your outgoing message.
Your message must be longer than two seconds and shorter than 90 seconds.
If you need a manual, you can download one at
Sep 11, 2011 | Vtech 2456 Cordless Phone
I have recorded an outgoing message. However, at the end of the new outgoing message an old obsolete outgoing message starts to play. How do I get rid of the old outgoing message?
You will need to remove the old message. There SHOULD be prompts. IF NOT try going to a very quiet room and hit record but do not say or make noise and this will record silence over the old and new message. Then attempt to retry.
ALSO - look for a 'reset' button and remove all batteries if you have power outage back up batteries.
Unplug the phone - and try again.
Here are the instructions from the manual:
To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Best of it
Gary @ Fix Ya
Jul 20, 2011 | NorStar M7324 Telephone
How do i get messages from remote location
To use your system from a remote telephone, you must first enter a 3-digit remote operation security code. The security code label is located on the bottom of the system.
1. Dial your phone number.
2. When your outgoing message is playing, enter your remote operation security code. Bd appears on the display to indicate the system is in remote mode.
If there are no new messages, you hear three beeps.
These are the remote codes available to you:
2 # Play all messages.
2 5 Play new messages.
3 # Delete all old messages.
7 # Record new outgoing message.
7 # Stop recording outgoing message.
8 # Record memo.
8 # Stop recording memo.
9 # Turn system off/on.
0 # Monitor the room..
Jun 12, 2011 | Radio Shack 3822 Digital Answering Machine
I am trying to record my personal greeting on my message machine with the DECT 6.0...can you please explain to me how I can record my greetings?
Which model phone do you have? For the CL82509 and related DECT 6.0, you need to set the outgoing message from the handset when the answering machine is on. (It can be turned on from the handset).
For the outgoing message: with the handset in Idle mode, press Menu/Select. Use the up (Dir) and down (CID) arrows to highlight Ans Sys Setup. Then press Menu/Select. Use the same arrow keys to select Announcement and press Menu/Select again. Press 7 to record a new announcement. At the tone, speak your message clearly then press 5 when you have ended the message. The message will play back.
This model's manual is available here: . See page 15 to set the answering system outgoing message. (This is different than Voicemail. To set up Voicemail, you will need to see your telephone provider's documentation.)
Most AT&T phone manuals are available here: .
I hope this helps.
Apr 01, 2011 | AT&T DECT 6.0 Cordless Phone System with...
Hi im trying to record a new message & i dont remember how. can u help me
To record an outgoing message, this is what you do-Press the voice mail key on the handset to access the answering machine. Then press 8 to record your message.
Hope this was helpful? Please comment for more information and thank you for using fixya
Jan 19, 2011 | Uniden DECT 6.0 Cordless Telephone...
Have a uniden dect 6.0 telephone and for some reason it has an A symbol there which it usually doesn't. People calling can't leave a message ... how can i fix it.
Probably the answering system is set to Announce only. (This gives the outgoing message but will not record messages.)
To change this (using the Uniden that I know), press Menu/OK on the handset. Use the Redial or Phonebook buttons to navigate the menu to AM Operation. Press Menu/OK and then navigate to Msg Length (as above). Press Menu/OK and choose the desired message length (the choices are 1 Min, 4 Min or Announce). Press Menu/OK to save the setting.
The manuals for all the Uniden DECT 6.0 phones are available as PDFs here: . Select your model and language and click on the model number. There you will get more information on setting the system.
I hope this helps.
Nov 23, 2010 | Uniden DECT 6.0 Cordless Phone ID
Info to change message on telephone dect 6.0 telephone Uniden dect 6.0
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time.
  1. Press the /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
Jan 06, 2010 | Uniden DECT 6.0 Cordless Telephone...
Understanding greetings and tables so that the outgoing main message can be changed for the holidays do you set the greetings/tables to change based on the time of day?
You can have the messages change using the greeting time tables, or you could record a seperate greeting and manualy change it from the standard greeting to the holiday greeting and back again at your leisure.
Dec 17, 2009 | NorStar M7324 Telephone
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
Lands Phones Logo
146 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
