Question about Apache HTTP Server
Apache Linux Problem
Running Apache on Linux suffering from this problem -
shmget: function not found
Any ideas?
  • 30 Answers
It means that apache want to use SysV IPC. (semaphore get function)
IPC:
Inter process communication
These software objects (semaphores,shared memory and signals) enables the processes to exchange information.
Apache processes wants to exchange information via semaphores but could not,
You current Linux kernel dont have SystemV IPC support.
You should build a new Linux kernel with a SystemV IPC support.
You will have to rebuild the kernel with that support enabled (it's under the "General Setup" submenu)
I hope you can compile a new Linux kernel, if not this can help:
http://www.freeos.com/articles/2589/
Posted on Jan 10, 2009
Have HP computer with windows 10 home and can't download linux into computer
go to the linux web site and down load ubantu to a usb stick
then burn a disc from that usb stick
use the disc to install the os on the computer
ubuntu is the same system as win 7 but with different names for the files and folders so it is easy to pick up and use
if you still have problems there are linux forums with plenty of help as to problems associated with using linux products
I found that it will not install directly from the usb stick and that has been mentioned in the forums but is readily capable from the disc for some reason or other
there are many linux operating system such as apache and the like but ubuntu is by far the easiest and most common
Libra is a very good office suite operating system from linux
Apr 20, 2017 | HP Computers & Internet
How to Build a LAMP Server?
LAMP
Linux
Apache web server
MySQL database server
PHP programming language.
The easiest way to create one I found is to install Ubuntu Linux. One of the software choices you have during installation is, "LAMP Server". Easy.
Oct 19, 2016 | Computers & Internet
How to download and install apache on rhel5
you can download
http://httpd.apache.org/download.cgi
www.techsolutionspot.com
Dec 30, 2009 | Red Hat Enterprise Linux ES 3 Standard...
How to download and install apache on linux5
Hi Follow the below procedures.
How to install and start the Apache or httpd service under Linux
by Milind
Q. How do I install and start the Apache or httpd web server under Fedora core or Cent OS?
A. Apache HTTP Server is a free software/open source web server for Unix-like systems and other oses.
Apache features configurable error messages, DBMS-based authentication databases, and content negotiation. It is also supported by several graphical user interfaces (GUIs) which permit easier, more intuitive configuration of the server.
Use rpm command to install Apache under Linux. You can also use up2date or yum command to install the same.
Task: Install Apache/httpd under Fedroa Core/Cent OS Linux
Type the following command if you are using Fedora or Cent OS Linux:
# yum install httpd
Now, start the Apache/httpd
# chkconfig httpd on
# /etc/init.d/httpd start
Task: Install Apache/httpd under Red Hat Enterprise Linux
# up2date httpd
Start the Apache/httpd
Task: Debian Linux httpd/Apache installation
Use apt-get command:
# apt-get install apache2
# /etc/init.d/apache2 start
Task: Verify that port 80 is open
# netstat -tulpn | grep :80
You can also install httpd from CDROM with rpm command:
# rpm -ivh httpd*
Configuration
Your server is started but you need to configure and use Apache as per your requirement. /etc/httpd/conf/httpd.conf (RHEL/Cent OS/Fedora Core Linux) or /etc/apache2/httpd.conf (Debian / Ubuntu Linux) configuration file. Use text editor such as vi to edit file. This file is very well documented or read official Apache configuration documentation for more information.
Uses of apache web server in open suse
Well, when using apache web server in open suse linux it is more secure and it is easy to manage than using apache in windows.
May 05, 2009 | Computers & Internet
Tell me thw uses of apache web server on open suse linux
Hi
The Web server is meant for keeping Websites. There are three ways a Website can be stored. They are:
1 - Default directory hosting
2 - Virtual directory hosting
3 - Virtual domain hosting
4 - Security
Etc....
Setting WebServer On Linux
Hello,You can try this http://www.goresellers.com/ site's more DNS ,here you can make your self as a reseller and get your expected DNS are very very cheap rate, also you got an internet business opportunity ,visit this site for more details.
Oct 18, 2008 | Computers & Internet
How to set a folder with small program to run on linux+apache
Dear Rajiv
First make sure that your Apache server is running properly.
For this type http://localhost and see the result.
If you want to test PHP you can create a php test file by yourself.
Goto the www folder in apache director. create a file , name it anything.php. Edit the file and simply write "phpinfo()" without quotes . check the output.
It means that your apache server is fully capable of PHP scripting.
Cheers, Parveen
Jan 25, 2008 | Computers & Internet
Apache 2.2
First, is it really necessary to restart the server? can you just restart the service from Administrative tools -> Services? (Not a solution but might help a little whilst you're looking for one :)
Is there a reason why you are running Apache on 8080? Is IIS on 80? If so, I wonder if it may be stealing 8080 from Apache when the Apache worker restarts after its maximum allowed run time. As to why IIS should be doing that, I have no idea :) Also, is Apache configured for SSL? If it is, then it will be trying to use port 443 as well, as may IIS - & thus the above error message may be due to both trying to use 443 rather than 80 or 8080.
If you really can't get this working then running Windows & Linux (a LAMP installation) under VMWare or something similar may be an option. It's not as drastic as it sounds - I've done this on a laptop PC & it works!
Nov 26, 2007 | Computers & Internet
How do I port forward 80 and do apache home website on verizon westell
As I had mentioned earlier to another gentleman, who had a similar issue; those SOHO routers and modem/routers have issues with their advanced functionalities which includes port forwarding. The first thing you must do is - Make sure 'block anonymous internet requests', is disabled in the router's settings - Go to the following website http://www.t1shopper.com/tools/port-scanner/ - Try to see if there is a service running on port 80 If the port is open (which I believe would be a least possibility), there is something else we are missing here. Get back to me with further observations Good Luck
May 16, 2007 | Westell Wirespeed VersaLink...
Apache HTTP Server Logo
252 people viewed this question
Top Apache Computers & Internet Experts
David Payne
David Payne
Are you an Apache Computer and Internet Expert? Answer questions, earn points and help others
